Member stretch65 Posted May 8, 2014 Member Share Posted May 8, 2014 Hi, Every time I create material groups in the Retopology Room and export out the model, the names that I've chosen for each group all have the string "_default" appended. This is kind of annoying. I can easily rename the groups back to what I wanted using a text editor, but is there any particular reason for this renaming? Can this behaviour be altered or is this just something Andrew hasn't fixed yet? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 8, 2014 Share Posted May 8, 2014 are you exporting an obj, dae or fbx... ? Quote Link to comment Share on other sites More sharing options...
Member stretch65 Posted May 9, 2014 Author Member Share Posted May 9, 2014 I'm exporting an OBJ file. But I just realized that the "_default" is actually the name of the UV set, isn't it? I guess I can see the logic in putting that at the end of each material name. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 9, 2014 Share Posted May 9, 2014 is the name of the UV set Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted May 9, 2014 Contributor Share Posted May 9, 2014 The 'drop-down list' next to the "Default" lets you change the name to what is preferred. Quote Link to comment Share on other sites More sharing options...
