How do i load penpacks?
Tiles
  • 1 year later...
Alpha Panel Drop-Down Menu
Brush-Components-Alpha-Panel-Drop-Down-3
A set of functions allowing you to view and change the current Brush Settings, Add and Create new Brush Folders, Add Brush “Packages” – as well as choose a display size for your Brush Alphas.
  • Refresh Alpha Preview: Refreshes the Alpha icon.
  • Brush Settings: Opens the “Brush Options” panel.
  • Add New Folder: Allows you to choose a directory of Alphas to be added to the “Folder” list.
  • Add Existing Folder: Allows you to choose a single Brush alpha from a folder, thus adding all the alphas in the folder to be included in the folder, now with the name of the chosen file, which is then listed in the “Folder” selection list.
  • Add Brushes From Package: Adds Alphas that have been packaged into a “Penpack” file format.
  • Folder: A selection list of all folders you have enabled 3DCoat to access. The icons from this chosen folder will then be visible in the “Brushes Panel”.
  • Tiny (or Normal, Large and Huge): Sets the Alpha icon set to the size specified.
