Tranquilizer Gun
FreezeFrame
A simple Tranquilizer Gun for first hard surface in 3D Coat. Basically almost done. Still needs a couple small parts. One more night it will be ready for retopo. I have to go over every part and check that it's centered along the axis. I had a real issue with this and cost loads of time.
......................Actually I just found using symmetry at the line to ensure it is at it's Global space I guess. Hard surface a little different.....just a little! not much....
post-37976-0-77848700-1400698822_thumb.j
From my custom concept here.
https://plus.google.com/101774691462828856815/posts/Sny2uYWSewh
Edited by FreezeFrame
Very Close to be finished. Still needs fine edits and a rear sight. Leaving all bumps to the normal for low poly.I don't know but some guns a extension off the lever come off where the clip is. I think some clips are right beside it? I'm probably going to change where the red line is to a continuous smooth piece. Now how do I do this low poly!! :( Maybe a project in a week or two.....!
post-37976-0-01232600-1400732594_thumb.j
Changed that piece really quick from the above and looks better(Obviously needs fixing around that area still after the change).....So next time I post it will be a finished high poly version.
post-37976-0-30107400-1400737948_thumb.j
