Member Ryder Posted May 28, 2014 Member Report Share Posted May 28, 2014 (edited) Hi All, Following (I hope) the "from scratch" tutorial with the Rat... Following the AUTOPO and heading into the Paint room... I see that I have too many layers or perhaps mesh objects... they are interfering with each other. Whilst leaving the Retopo room, I first did a Merge with NM (per pixel). When I got to the paint room, I was presented with what you see attached: It appears that the density regions are still visible and are on a separate mesh... and when I attempt to paint, only the object with the density mapping receives paint. The other mesh does not receive paint. I believe that this object that was created in the Voxels room... but I can't seem to delete it from the vox tree (it ignores delete requests silently). It is now listed as a surface. What are these two objects? I assume one is the original voxel edit... and the second is a surface from AUTOPO... but... why do I have both still... and unable to delete the voxel object? Why is it interfering with the paint room? Thanks so much for your kind help, R Edited May 28, 2014 by Ryder Quote Link to comment Share on other sites More sharing options...
Advanced Member vidi Posted May 28, 2014 Advanced Member Report Share Posted May 28, 2014 Go in the voxel tree Tab and hide the voxel object . Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 28, 2014 Report Share Posted May 28, 2014 Show voxels in paint room = OFF Quote Link to comment Share on other sites More sharing options...
Member Ryder Posted May 30, 2014 Author Member Report Share Posted May 30, 2014 Thank you both for the suggestions. That did the trick! Quote Link to comment Share on other sites More sharing options...
