Useful angelscript for version 4 ! - links (& v2022)
Carlosan
  • 7 months later...
  • 5 months later...
I has released some short scripts for beginner like me. :huh:
https://github.com/coverman03/3dcoat_script
dude these scripts are pure gold for retopo..thanks you for making them
  • 6 months later...
  • 4 weeks later...
  • 3DCoat Developer
Added a part of documentation for the 3DCoat's scripting: https://bitbucket.org/3dcoat/3d-coat-scripting-docs
In a short time this docs will be published on the official site... For now just open `index.html` from the zip-file (see link above).
post-39279-0-60357700-1458656021_thumb.p
  • Like 2
Wow, the documentation is HUGE! It will take me some time to dig through it. :D Thank you Andrey! :good2:
Edited by ajz3d
  • 1 year later...
I'm currently revising my scripts as some of them seem to be broken by two regressions and a recent change to ShowFloatingMessage function.
In fact, scripts that don't use modal dialog callbacks or custom buttons you can fix by yourself, simply by editing each line that include ShowFloatingMessage function and adding false as its third argument. :)
The rest of the scripts got replaced by new 3DC features, so I'm marking them as obsolete.
Edited by ajz3d
  • 5 months later...
Carlosan
ajz3d was awarded the badge 'Great Content' and 1 points.
GitHub is the new home of my tiny scripty-scripts.
https://github.com/ajz3d/3dc-scripts
Some scripts had to go, but some new were added in their place. Erm... at least one... for now... :p:
New ideas and contributions to existing scripts are welcome!
//edit
link to v2021
https://github.com/ajz3d/3dc-scripts/tree/3dc2021
  • Like 2
  • Thanks 2
  • 4 years later...
  • 2 years later...
3DCoatScripting
https://3dcoat.com/files/scriptdocs/AHowRunOwnScript.html
3DCoat scripts are simple text files with AngelScript code
If you're familiar with C++, then using AngelScript will cause no problems. AngelScript code works very fast, that's why you may make pretty complex stuff.
It's good to use a text editor with syntax highlighter.
For instance, Notepad++ is a good choice. In "Syntax" menu choose "C++".
After creating a text file run it inside 3DCoat by choosing "Run Script" in "Scripts" menu.
What to start with? Start with primitives.
