Can't use some tools like Grow in the voxel room the way I could before.
Sladus
I try to use some of the buttons on the left such as grow, it starts a selection box that I can drag to size and then release to Grow the object. Before, I could just hold grow and it would do its thing. Is there a setting that caused this?
A E-panel selection box (spline) will not grow till you release the mouse button.
If you want the area under your brush cursor to grow without moving the mouse, deselect "grow on pen motion" under the Voxel heading in the top menu.
You will need to use a regular brush ( not  a spline)  under the e-panel as well, then choose the brush alpha you so desire to use.
To return to regular brushing re-select "grow on pen motion"
Edited by digman
Also brush radius setting effects depth with grow e.g if you're creating a "blob" in empty space with a selection mode.
