Advanced Member worldcrafter Posted June 29, 2014 Advanced Member Report Share Posted June 29, 2014 (edited) sometimes (seemingly random) the large array of brushes is reduced to only 11. why is this and how do i change it back in the paint room Edited June 29, 2014 by worldcrafter Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted June 29, 2014 Reputable Contributor Report Share Posted June 29, 2014 In the brush panel on the far right is a drop down arrow. Drop down the list, go to "Folder" and choose default. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 29, 2014 Reputable Contributor Report Share Posted June 29, 2014 In the brush panel on the far right is a drop down arrow. Drop down the list, go to "Folder" and choose default. ....or under FOLDER, choose the one you want to use. If you downloaded and installed the Brush packs in the 3DC Exchange Library section, you will probably see those among the choices. Problem is, by default 3D Coat remembers and loads the brush alpha for each tool you use. That's why it keeps switching you back. You can disable that by going to the EDIT menu > PREFERENCES > under the General tab...midway down, un-check "Remember Brush for each Tool" 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member worldcrafter Posted June 29, 2014 Author Advanced Member Report Share Posted June 29, 2014 Thanks for clear instructions and explanation AbnRanger Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 30, 2014 Reputable Contributor Report Share Posted June 30, 2014 Thanks for clear instructions and explanation AbnRanger Glad to help. That's the inevitable result of other people's requests. It may be an awesome time-saver for them, but be a PITA to you. Someone, a long time ago asked Andrew to make it so they didn't have to keep changing their brush alpha and draw mode each time they go back to a tool they were using previously. That's cool in some situations, but a major pain in others.I usually un-check it myself, and just create tool presets with those brush alphas and such. Quote Link to comment Share on other sites More sharing options...
