Weapon Retopo
FreezeFrame
Well finally got around to weapon retopo.
I probably went about it the hard way, of course!
I retopoed every piece at the mirror symmetry line. So both sides of every object are mirrored and split at the center.
Actually a couple parts left(main housing needs to be done in Blender 3D, it's like a cave and auto-po can't handle it.).
Now I have to line up loops and join seams.
Does anyone actually import weapons in separate pieces like that(but joined as one, except animation parts)?
It would work but I don't know how acceptable it is, or actual problems with it.
I probably should have joined some continuous parts and retopoed, would have saved time actually.
Well it was good practice retopoing different shapes anyways!
post-37976-0-64256600-1404603020_thumb.j
Edited by FreezeFrame
https://3dcoat.com/forum/index.php?/topic/16373-weapon-retopo/
Ya I was just thinking though.
Yes there would be hidden faces to the viewer which is basically useless.If it was put in a game engine as is.
Poly wise though I would end up with just about the same amount of poly's or actually it may raise the count,
because when making a continuous mesh, all those fine lines and edges cost poly's.
Wouldn't really matter to me!
Just curious as usual.......Anyways. I will let it sit for a day.
https://3dcoat.com/forum/index.php?/topic/16373-weapon-retopo/#findComment-110595
I guess that's the way it goes lol.....
I'm not sure why I thought it has to be continuous for weapon retopo. Join where possible I guess.
I must have seen a few modeled this way, probably because they were started in low poly to begin with.
Ok, well that opens some design ideas!!
Almost done. 1 more and 5 retoped models ready for paint and renders!
https://3dcoat.com/forum/index.php?/topic/16373-weapon-retopo/#findComment-110602
