Problems with UE4 importing assets
Sladus
Does anyone else have problems importing fbx files into UE4? I import the fbx, color, and normal maps and almost everything has at least one black spot on it after rebuilding lighting. Other than the black spot, everything looks awesome.
post-38344-0-35495500-1404619667_thumb.p
hmmm... is it any hidden geometry :huh: ?
Oh Great!! I notice the hidden geometry when deleting faces from auto-po. Not sure if they are placed there before deleting or after.
I'm sure it's a good thing though to check off, weld vertices at the same point in case of underlying faces? maybe IDK!!.
All this time I thought there was a centerline problem in 3D Coat, because of other posts and problems.
Specifically the hidden geometry/ triangle problem at the symmetry line.
It works fine in virtual mirror mode you can go past the line if in a hurry! Or no virtual mirror and snap to the line. Whats the problem!!
Is there a way to check for underlying floating faces?
It may have been some hidden geometry, but I fixed it with playing around with the Lightmass settings in UE4. Looks good now. Thanks.
Also, I don't know how to find hidden geometry. I'm very new to this.
Edited by Sladus
  • 3 weeks later...
