Uv Template - Weld Vertices
FreezeFrame
I have a mesh that some how a couple verts are not welded and have split ends.
Not sure where it happened, in Blender 3D or 3D Coat after unwrapping?
I had some issues in Blender with unwelded verts after deleting faces and adding new faces/loops.
Anyways....
Can I weld vertices within the UV template preview window, from the retopo or UV room?
It's a very tiny area on the mesh and there's no way in the viewport.
I could use the applink back to Blender to weld.
Just wondering........
Edited by FreezeFrame
https://3dcoat.com/forum/index.php?/topic/16465-uv-template-weld-vertices/
Ah, it's ok. I unwrapped again and it dissapeared. Weird fluke. Never had it happen before.
Basically solved here. I don't thin vertices can be welded in the uv preview viewport...IDK
