Shaders
Hello Akira!
I am starting to to study cgshaders, but I have some difficulties. For example I really would like to know how you can create a matcap shader. Theorically I thought that for every normal you substitute a pixel of your ball image, but I am not sure.
Can you give me some suggestions please ? Thank you !
Hello Akira!
Hi, I won't call them matcap shaders, I don't know how exactly matcap shaders work either.
The basic idea of picmat shaders is to use view-space normal to index the pixel of the shader ball texture, you'll find good explanation here:
see page 109 ~ 112
http://developer.nvidia.com/object/nvision08-bwotf.html
Hope this helps.
akira.
  • 4 months later...
Sorry to hear that :(
I'll keep on looking for a solution for this.
Does these circles appear in GL version too?
ARG, I have these rings!
I assumed the rings were just an artifact and part of the way it was supposed to be (although they didn't look nice, I just don't use them)
Anyway, I have the nVidia QuadroFX 3450 with 256MB and the rings show up in GL and DX...
I still get all the same rings as mentioned before... any thoughts?
  • 1 month later...
Sorry philnolan3d, I didn't mean how to use ball images, but how to write the code to use them
if all you want is to create your own PicMat style shader, right click on any of the existing PicMat shaders (e.g. Red Plastic), and "Construct New Shader", then give it a name, then when the settings box comes up, Choose a new picmat image. you don't HAVE to write any code, because the shader code will be copied automatically for you.
That's not to say you can't write shaders on your own... because you can. I have learned a lot just by opening up the shaders, copying them and experimenting. There are a few little quirky things to 3DC implementation of the GLSL and HLSL shaders but for the most part pretty standard vertex and pixel shaders.
However, I think you really were just asking about how to use your picmat images, and the short answer - copy a shader, replace the picmat. the shader name is the name of the folder. couldn't be much more simple!
  • 4 weeks later...
Hi Guys,
I modified an existing shader to get this result, post-904-12626683198693_thumb.jpg which is exactly what I'm after(essentially the tree shader with normal mapping for doing landscapes and the like). But a few things were amiss.
First, I'm not getting any thumbnail showing up in the shader pallette.
Second, when I try to bake out I'm just getting black on my color layer and my normal textures are being ignored.
Third, My texture selection buttons don't work at all for the normal map.
In short.... It's useless :(
As I'm not a coder at all, I'm actually pretty surprised I got this far; but if anyone can see it in their heart
to make their own modified shader to do this, or point me in the right direction I'd be really grateful.
Here hoping,
Heath
Thanks Phil,
That got that problem solved. I think the others might be tied into the "Method" section of the variables XML for the shader. When I don't alter the XML file at all, the shader bakes, but only respects the sides color and normal maps. For those in the know, here's the HLSL code with the changes (don't laugh :) ).
// Vertex shader
float4x4 g_WorldViewProjectionMatrix;
float4x4 g_WorldMatrix;
float3 g_ViewerPos;
float4 Sphere;
float OverallScale;
float4x4 ShadowTM;
struct VS_INPUT {
float3 Pos : POSITION;
float3 Normal : TEXCOORD0;
struct VS_OUTPUT {
float4 Pos : POSITION;
float3 N : TEXCOORD1;
float3 Ps : TEXCOORD3;
#ifdef SHADOWS
float3 SPos : TEXCOORD2;
#endif
VS_OUTPUT main(const VS_INPUT In) {
VS_OUTPUT Out;
float4 P = float4(In.Pos, 1.0);
Out.Pos = mul(P, g_WorldViewProjectionMatrix);
Out.N = In.Normal;
Out.Ps = In.Pos*0.005/OverallScale;
#ifdef SHADOWS
Out.SPos = mul(P, ShadowTM);
Out.SPos.xy += float2(1.0/4096.0f,1.0/4096.0);
#endif
return Out;
// Pixel shader
struct VS_OUTPUT {
#ifdef SHADOWS
#endif
sampler ShadowSampler;
sampler CustomSampler1;
sampler CustomSampler2;
sampler CustomSampler3;
// Change number one added a couple of custom samplers
sampler CustomSampler4;
sampler CustomSampler5;
float4 Color;
float4 CurrColor;
float4 ColorMod;
float4 SpecularColor;
float3 LDir;
float3 VDir;
float LDiffuse;
float LAmbient;
float Opacity;
float ShadowMin;
float Bumpness;
float Specularity;
float SpecularPower;
float4 main( const VS_OUTPUT v ) : COLOR {
float mpl=1.0;
float4 mxy=tex2D(CustomSampler1,v.Ps.xy);
float4 myz=tex2D(CustomSampler1,v.Ps.yz);
// Change number Two changed custom sampler for zx
float4 mzx=tex2D(CustomSampler4,v.Ps.zx);
float4 nxy=tex2D(CustomSampler2,v.Ps.xy);
float4 nyz=tex2D(CustomSampler2,v.Ps.yz);
// Finally changed custom sampler for zx
float4 nzx=tex2D(CustomSampler5,v.Ps.zx);
float wxy=v.N.z*v.N.z;
float wyz=v.N.x*v.N.x;
float wzx=v.N.y*v.N.y;
float3 dN=float3(nxy.x-0.5,0.5-nxy.y,0.0)*wxy*Bumpness;
dN+=float3(0.0,nyz.x-0.5,0.5-nyz.y)*wyz*Bumpness;
dN+=float3(0.5-nzx.y,0.0,nzx.x-0.5)*wzx*Bumpness;
wxy*=wxy;
wyz*=wyz;
wzx*=wzx;
mxy=(mxy*wxy+myz*wyz+mzx*wzx)/(wxy+wyz+wzx);
#ifdef SHADOWS
float3 m=tex2D(ShadowSampler,v.SPos).xyz;
float3 d=float3(1.0,1.0/255.0,1.0/255.0/255.0);
mpl=clamp(2.0-(v.SPos.z-dot(m,d))*120,ShadowMin,1);
#endif
float L=length(v.N);
float3 N=normalize(v.N-dN);
float3 refl = VDir-2.0*N*dot(VDir,N);
float S = dot(refl,LDir);
float dd=clamp(L-1.0,0.0,1.0);
S=clamp(S,0.0,1.0);
#ifdef AOPASS
float D = LAmbient-LDiffuse*dot(N,LDir)*mpl;
#else
float D = -LDiffuse*dot(N,LDir)*mpl;
#endif
float4 C=ColorMod*D*mxy*2+SpecularColor*pow(S,SpecularPower*mxy.w)*Specularity*mpl*mpl*mxy.w;
float4 c1=tex2D(CustomSampler3,float2(dd,0));
C=lerp(C,c1,dd);
C.w=Opacity;
return C;
Ultimately I'd like to get a fully fledged terrain shader.I've been having a lot of fun using 3d coat for doing a mesa desert scene I'm working on and would like to do more, but take out a bit of the textureing work.
The final custom settings I'd like are:
Top col map
Bottom col map
side col map
Top norm map
Bottom norm map
Side Norm map
Slope (Top to Side Blend) Slider
Bump Amount Slider
Top Specular Amount Slider
Side Specular Amount Slider
Bottom Specular Amount Slider
Cavity Col picker
Cavity Col affects COL/SPEC check boxes
Maybe this belongs in the features request thread, But as it's the ultimate goal of my current dilemma I thought I'd post it here.
Any help appreciated,
Heath
