Advanced Member Skaven252 Posted December 25, 2008 Advanced Member Report Share Posted December 25, 2008 The voxel models seem to have bubbles, or pockets of air inside them. This probably isn't a huge problem, but it does add to the polygon count and has a few times messed up my model when I accidentally cut into one of these pockets. Yeah, to me it seems like a feature, not a bug. Voxels are really cool because it is actually possible to create hollows inside your models. But indeed, some sort of "detect and fill hollows" voxel operation feature could be useful for the reasons you mentioned. How complicated is it to detect empty spaces that are completely surrounded by voxel volume? Quote Link to comment Share on other sites More sharing options...
Contributor tree321 Posted December 25, 2008 Contributor Report Share Posted December 25, 2008 Bugs:GL64 Alpha 47. Clone object-transform-click object turns red and stays red.Using brushes clears it up. Transpose: 1.When you clone an object and use transpose-select with pen on that object it doesn't work.If you use it on original object it selects the cloned object.2.General selection:Sometimes when clearing selection and trying to make a new selection in same area it doesn't work. Undo problems as mentioned when using certain scene tree functions such as clone. Sub object mesh disappears when sculpting nearby object. xp 64 9800gt 8 gig ram amd quad core Quote Link to comment Share on other sites More sharing options...
Advanced Member lc8b105 Posted December 26, 2008 Advanced Member Report Share Posted December 26, 2008 Shader bug in Alpha 46 OS X version (default and Lamblight) As show in the pictures: Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted December 26, 2008 Report Share Posted December 26, 2008 I've mentioned this cursor freezing before but here's a video. It happens every once in a while (once or twice a day), after each brush stroke the cursor freezes for 5 or 6 seconds, making it almost impossible to get anything done. The only fix seems to be to save my work and restart the program. I've checked the RAM usage and for this model it's only around 60%. The CPU usage seems fairly low, around 30-40%, but that meter also freezes for the same 5-6 seconds. http://screencast.com/t/Mt8urSXmHL Quote Link to comment Share on other sites More sharing options...
Advanced Member Jokermax Posted December 26, 2008 Advanced Member Report Share Posted December 26, 2008 Brush curve shape inside brush circle does not update - it's been like this for a couple versions. Can you please fix it in the next release, it is very useful to be able to see the curve. Thanks! Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted December 26, 2008 Report Share Posted December 26, 2008 Brush curve shape inside brush circle does not update - it's been like this for a couple versions. Can you please fix it in the next release, it is very useful to be able to see the curve.Thanks! Yeah I mentioned that when it first started, I'd love to see that fixed as well. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted December 27, 2008 Report Share Posted December 27, 2008 Render bugs: 1. If you render with the Transform gizmo visible that gets rendered as well. (see attachment) 2. With the new Vox Tree the currently active object is a lighter shade than the rest. This is also visible when rendering. Quick fix is to have a non-important object in the tree. Select that one and hide it before rendering. 3. Not sure if this is a bug or a feature. When the camera animates around an object during a render the camera moves but light stays still. So one side of the object will always be dark. 4. My most recent render was going fairly quick. Maybe 2 seconds for every 10 rays, then after about 230 rays or so it suddenly starts going much slower like 30 seconds for every 10 rays. My fix is to just click the program's title bar. The program goes all black and says "not responding" for a few seconds, then it goes back to rendering at the fast speed. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted December 27, 2008 Contributor Report Share Posted December 27, 2008 2 other bugs: alpha47(both dx and opengl) I get that on this simple box made from the default sphere ,when I try to increase reolution twice. also when I use the "export this object" option in the voxtree rmb menu the created .obj scale is always wrong on an axis. But when I use the "export full scene" option there is no problem. Quote Link to comment Share on other sites More sharing options...
Advanced Member Frankie Posted December 27, 2008 Advanced Member Report Share Posted December 27, 2008 V47. In the tree view, an object that is hidden cannot be deleted. Quote Link to comment Share on other sites More sharing options...
Member druitre Posted December 29, 2008 Member Report Share Posted December 29, 2008 alpha47 (DX and GL CUDA) - In the treeview, I cannot delete subobjects when there are (other) subobjects set to invisible. - Everytime I save an object with subobjects and then re-open it, 3DC adds a default sphere subobject. - When I activate the transform tool, the grid disappears. - Undo (still) sometimes 'loses' the entire subobject, as if it's hidden and nothing will bring it back into visibility. Q6600 2.4GHz 4 Gb Vista 64 Geforce 8800GTS 640, driver 7.15.11.8060 DirectX 10 CUDA 180.60 Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted December 29, 2008 Report Share Posted December 29, 2008 alpha47 (DX and GL CUDA)- Everytime I save an object with subobjects and then re-open it, 3DC adds a default sphere subobject. - Undo (still) sometimes 'loses' the entire subobject, as if it's hidden and nothing will bring it back into visibility. The re-open thing happens to me every time. I noticed the Undo thing once yesterday, I also noted that the number of polygons was always 0 for that object. One more thing: I created a subobject, then tried to make a curve but nothing happened when I hit Enter, so I thought maybe there needs to be an object for it to start from. So I grabbed the Sphere tool and tried to create a sphere on the empty layer. 3DC froze up (all black) then eventually crashed. I sent in the bug report that came up. Another bug: The scaling of points on a curve is not working correctly. It seems to be ignoring points that are added in the middle (green dot). In this video I made a straight curve for the character's arm, then after it was in the correct position I added three more points in the middle so I could adjust scale for the elbow and muscles on either side. http://screencast.com/t/nDDlxlhZYA Here's more: Something is wrong with Lamblight, see in this screenshot different objects look different from each other: http://www.screencast.com/t/VpSF87al If I turn on shadows the whole thing goes dark: http://www.screencast.com/t/AzSxqvjVWi These problems seem to occur as the resolution is increased. Here's a video showing that. I have also noticed sometimes the strange effects change, depending on how close you are zoomed in. I tried to show that t the end of the vid, but it didn't happen this time. http://screencast.com/t/O2WLHqIdc0C Another video: This one shows problems with the Build tool. geometric patterns and tears appear while using it. http://www.screencast.com/t/l3BizosZ8 Quote Link to comment Share on other sites More sharing options...
Advanced Member Skaven252 Posted January 5, 2009 Advanced Member Report Share Posted January 5, 2009 The Mask doesn't seem to work correctly if you increase the resolution of the voxel object. Try this: 1. Start sculpting on an object through the mask using the Build, Extrude or Airbrush tool. The mask is projected on the object correctly. 2. Click "Increase Resolution" 3. Paint on the object again using the same mask. It seems to be projected onto the object at half the size. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted January 6, 2009 Contributor Report Share Posted January 6, 2009 a very small thing but I guess I need to report this... alpha47 64 cuda GL (DX didn't have this issue) when I use transform sometimes (not all the times) a selection gradient appear a stays on the model forever(meaning closing and loading back file won't help) it's the kind of selection gradient you get when you use transpose but I get it with transform I tried incremental render on/off I tried to switch to transpose and hit the clear selection button(a wild guess) but it does nothing. here is an exemple. sometimes it's more extreme like the whole model will be green or pink. I'm starting to think 90% of the problems I had so far are related to my quadrofx1700, but it just a feeling... Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted January 7, 2009 Report Share Posted January 7, 2009 Strange render bug. When you do an animated render is it just taking and saving screenshots? I set one up and let it go while I surfed the web and did other things. When I went back to check on the files that came out the first couple were fine, but the rest were pictures of my email, my web browser, etc. Quote Link to comment Share on other sites More sharing options...
Advanced Member lc8b105 Posted January 8, 2009 Advanced Member Report Share Posted January 8, 2009 Strange render bug. When you do an animated render is it just taking and saving screenshots? I set one up and let it go while I surfed the web and did other things. When I went back to check on the files that came out the first couple were fine, but the rest were pictures of my email, my web browser, etc. Yes, I've met this problem before on windows version, it just like take screenshot; but on Mac version there is no such problem. I don't know why, but may be Andrew can improve this. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted January 8, 2009 Report Share Posted January 8, 2009 I understand there's something different about the way macs take screenshots. Perhaps that's related. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted January 8, 2009 Report Share Posted January 8, 2009 This one's interesting. I sculpted this bit of ground with a dirt road. http://screencast.com/t/1NZvvqXTL Then I retopologised it and used Merge Into Scene to make the details into the normal map. What I got was this: http://screencast.com/t/fYdJVpissvK I don't care about the rounded corners of the model so much, I expected that to happen, it's these weird stripes that bother me. I don't really care about the bottom since I'm not using it for anything, but I just thought I'd show these strange geometric patterns that appeared. They looks something like the "bubbles" that appear inside the VS model. http://screencast.com/t/sIUrhScn Quote Link to comment Share on other sites More sharing options...
Advanced Member Skaven252 Posted January 8, 2009 Advanced Member Report Share Posted January 8, 2009 Then I retopologised it and used Merge Into Scene to make the details into the normal map. What I got was this:http://screencast.com/t/fYdJVpissvK Hmm, I wonder if that bug is akin to what I posted here? (maybe I shouldn't have made it into a separate topic?) There seems to be some artifacts introduced when voxels are projected to height maps. Something tells me it happens where the retopo polygons intersect with the voxels... but not sure if that's the case. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted January 9, 2009 Report Share Posted January 9, 2009 After making my above object I saved it as a new increment. Later my computer crashed and I restarted. Now when I try to load that file 3DC crashes every time. Andrew, if you want the file it's like 90MB so I could send it via sendfile.com or megaupload.com, something like that. Here's a minor thing. When I hit Save Incremental it opens the Save As dialog. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted January 9, 2009 Author Report Share Posted January 9, 2009 After making my above object I saved it as a new increment. Later my computer crashed and I restarted. Now when I try to load that file 3DC crashes every time. Andrew, if you want the file it's like 90MB so I could send it via sendfile.com or megaupload.com, something like that.Here's a minor thing. When I hit Save Incremental it opens the Save As dialog. I have received file and will look it very soon. I was slightly busy today and was not able to do it immediately. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted January 9, 2009 Author Report Share Posted January 9, 2009 After making my above object I saved it as a new increment. Later my computer crashed and I restarted. Now when I try to load that file 3DC crashes every time. Andrew, if you want the file it's like 90MB so I could send it via sendfile.com or megaupload.com, something like that.Here's a minor thing. When I hit Save Incremental it opens the Save As dialog. I have opened file successfully (there is valley with road). But I have 8GB RAM... Maybe it is leak problem, it really takes more memory then need. I will fix this mem issue in next update. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted January 10, 2009 Report Share Posted January 10, 2009 Oh great thanks, yeah it couldn't have taken 8GB when I was working on it I only have 6GB. I've tried repeating the process and the same thing happened I couldn't open the file without it crashing. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted January 10, 2009 Contributor Report Share Posted January 10, 2009 It is more a problem than a bug.But for users in the future it might be a wall. The "change parent" submenu in the voxtree rmb menu gets quickly too long and goes even beyond the screen space even if my monitor resolution is at it's maximum,the reason for that is because it is displaying all objects in the tree regardless of the parenting.So now if I add new object to the tree they are unaccessible in the "change parent" menu,Maybe the menu should split into submenus at branch junctions like voxtree or maybee globally expand in another menu page and so on.(up to let's say 4or 5) (but spitting into submenus at branches junctions would be better for navigation I think) It would be also great if we could assign hotkeys to the voxtree functions ex:delete,clone,set a specific shader(assigning seems to work as I clearly see the hotkey being displayed beside the function but when I press the said hotkey nothing happens) Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted January 12, 2009 Contributor Report Share Posted January 12, 2009 I've been having some "swapping" issues in the voxtree. meaning: I sculpt on an object in the tree then if I delete all the others object and rename the object to another name,save the file to another name now if I try merge the .3b to the previous file the object swap place with the object from which came from. to reproduce: open a AandB.3b and AlternateFromA.3b separatly just to look how they look(remembering shape difference). then open AandB.3b and use merge .3b in voxtree and choose AlternateFromA.3b now AlternatefromA object and A object should have swapped place in voxtree. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted January 14, 2009 Report Share Posted January 14, 2009 Very tiny, almost nothing, really just cosmetic bug. The 3B files have no icon, at least in Windows. Well they do, but it's just the generic "blank piece of paper" icon. If I associate the file with 3DC now the icon is the same piece of paper, but it has the 3DC logo on it. Slightly bigger. The E panel shapes no longer work with Hide. Quote Link to comment Share on other sites More sharing options...
Advanced Member erklaerbar Posted January 14, 2009 Advanced Member Report Share Posted January 14, 2009 there is some weird exploding vertices issue with this quadrangulated mesh on subdivision: Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted January 14, 2009 Applink Developer Report Share Posted January 14, 2009 here is one. 1. Go to Volumetric Sculpting and do a model 2. Voxtree -> Quadrangulate and paint 3. Save your .3b file 4. RE-open your 3b file and go to Sculpt mode 5. Your model is at least 200% bigger than your orginal mesh. But in the end I have to add that this program is amazing... A big thanks to Andrew Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted January 15, 2009 Contributor Report Share Posted January 15, 2009 ALPHA49 64 cuda gl/dx a very small bug: the + icon n the voxtree displaying if an object got children disappeared, it was clearly there when I started opening files with alphah49,I'm sure of it... Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted January 15, 2009 Report Share Posted January 15, 2009 Something is still wrong with Curves. The scale is kind of flickering it around instead of smoothly scaling up or down. After painstakingly getting the curve just the way I like it I hit Enter and nothing happens. Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted January 15, 2009 Applink Developer Report Share Posted January 15, 2009 here is one more. 1. Open 3d-coat program. 2. turn off your combuter using hibernate. 3. turn on your computer and try to use 3d-coat.... I have Windows Pro 32bit and I was using alpha 49 Quote Link to comment Share on other sites More sharing options...
