Simplifying STL files
jvo
Go to solution Solved by polyxo,
  • Solution
Yes you can.
  • File/Import/Mesh for Voxelization
  • In the panel which comes up check "import w/o voxelization (then it comes in as the raw mesh)
  • File/Export Object – in the Exporter you can dial in a value or drag the simplification value.
Hope that helps.
Edited by polyxo
