Member Vaiktorg Posted December 13, 2014 Member Share Posted December 13, 2014 Every time i import an .obj to 3DC in any way!Import > .obj or File > New > Vocel Sculpting/Surface Sculpting The .obj appears off center and it really bothers me! I tried a lot before coming here, but i cant quite get it to work. Quote Link to comment Share on other sites More sharing options...
Contributor Solution Malo Posted December 13, 2014 Contributor Solution Share Posted December 13, 2014 After choosing your file for import, a new windows gets open where you could scale, rotate and do other stuff. In this menu, simple click on Reset Axis and Reset Space and then scale your object to your needs and hit apply. If that wont helps, check your export options where you have createt your file. Maybe it is out of center or gets after export. Quote Link to comment Share on other sites More sharing options...
Member Vaiktorg Posted December 13, 2014 Author Member Share Posted December 13, 2014 Thank You! Quote Link to comment Share on other sites More sharing options...
