fuzzzzzz 20 Report post Posted March 28, 2016 4.5.33 [beta] - Shaders updated, correct rendering in render room, good sss for sculpt objects. See screenshots: - Extrude faces, extrude vertices, Intrude, Shell implemented for retopo/select/faces mode. - RMB->Share item/folder works correctly for PBR materials - If "Material preview" window is collapsed it will not pop-up again when you are switching rooms. Thanks you Andrew, for the update . I would as a reminder to redirect you on this old feature request i made long time ago : http://3dcoat.com/forum/index.php?showtopic=17329 the reason that make me purchase for a Zbrush license and never come back to 3dcoat. just had a try with the latest 4.5 33 but exact sample problem, i just try to setup the lattice and i did something wrong i can't to undo and the masking can be reverted... Another thing i hate with 3Dcoat is the confusion with symmetry tool, it create new polygons that are hidden into the model you must to clean up disabling the sym and then delete one complete model side, and if, all the vertices are no longer exactly at 0.000 on the symmetry axis. you try to select them and move them all to snap the 0, using numeric dialog from the transform option panel, but it don't move each point to 0 on the sym axis, the other that were good before will being wrong after that. This issue with symmetry happens since the first build i try when i purchase for a license of 3dcoat, i ever had some issue with every model i made with 3dcoat. you should really polish Andrew. every time i notice there is new beta version, that looks great, few hour later someone report for a new major bug , basically when you read the detail of the bug, it make me think that the version is not a version that can be use, ust to prevent from some various bug that could happen at anytime, so finally i download the new version and i never install it because someone report a bug. It all about the frequency of the release of a new beta versions, that has good point to get new version every weeks. but you should consider that you make a private beta, that you share with some guy from this forum, and when all reported bug get fixed, you can release a public beta version that make more sense. Many in the software editor delivers beta version that people use in production. when pixologic release a version there is no bug at all, or so less that we can survive for many month without any patch fix. so as customer and as the beta version is a service offered to the customer i would like to have the possibility to work with more recent build but that has a better stability. What do you think ? sharing this with you is only some kind of help to make more people happy with 3dcoat.. Best regards, Nicolas sorry for being rough like that, but i d to let you know about This a core tools, for any modeling app, and if that doesn't work well, you can have the best feature ever, 3dcoat is just painful to work with, i hope it change, but i will not upgrade to V5. Share this post Link to post Share on other sites
Andrew Shpagin 1,463 Report post Posted March 28, 2016 A hidden retopo group, that lies on the same UV-set as the retopo group I'm currently working on, regularly gets its UVs all screwed up. What I mean by that, is that the UVs of this hidden group get somehow reapplied per-face, and I end up with 2096 separate UV islands. Last time it happened was right after I unwrapped the UV-set. Oh, and I'm experiencing this in 4.5.32 and 4.5.33. Is there way to reproduce? Or send me scene. Share this post Link to post Share on other sites
philnolan3d 252 Report post Posted March 28, 2016 Always happy to see an update! Share this post Link to post Share on other sites
dimitribastos 141 Report post Posted March 28, 2016 4.5.33 [beta] - Shaders updated, correct rendering in render room, good sss for sculpt objects. See screenshots: - Extrude faces, extrude vertices, Intrude, Shell implemented for retopo/select/faces mode. - RMB->Share item/folder works correctly for PBR materials - If "Material preview" window is collapsed it will not pop-up again when you are switching rooms. Amazing. Thanks. Is there a way to implement SSS on panting workflow? Share this post Link to post Share on other sites
BeatKitano 321 Report post Posted March 28, 2016 I've yet to understand how SSS works (EDIT: ok found it, I expected it to work with another shader with the SSS setting) but the cavity/bulge RealTime when sculpting is a stroke of genius. Thanks ! 1 Share this post Link to post Share on other sites
AbnRanger 1,537 Report post Posted March 28, 2016 I've yet to understand how SSS works (EDIT: ok found it, I expected it to work with another shader with the SSS setting) but the cavity/bulge RealTime when sculpting is a stroke of genius. Thanks ! By the way Beat...some of the issues with exploding meshes, you mentioned in the past, may have been addressed 3 builds ago. I had similar issues but it seemed related to using UNDO. I was able to reproduce the problem twice in about 20 minutes, had it recorded and sent to Raul. He supposedly fixed it. You may want to experiment with it a bit and see if it resolves your problems or not. 1 Share this post Link to post Share on other sites
Taros 370 Report post Posted March 28, 2016 Bug: No free transform possible after face normal extrude. Try to transfor new extruded face. It is possible in normal direction only! Please fix this. Or do I something wrong? Additionally: Vertex normal extrude seem to be the same like face normal extrude. 1 Share this post Link to post Share on other sites
Tony Nemo 398 Report post Posted March 28, 2016 In Retopo: "RFill works a treat! Compared to Cap, it gives quads. Very handy. 1 Share this post Link to post Share on other sites
BeatKitano 321 Report post Posted March 28, 2016 By the way Beat...some of the issues with exploding meshes, you mentioned in the past, may have been addressed 3 builds ago. I had similar issues but it seemed related to using UNDO. I was able to reproduce the problem twice in about 20 minutes, had it recorded and sent to Raul. He supposedly fixed it. You may want to experiment with it a bit and see if it resolves your problems or not. I may confirm this soon. Started doodling to test the new cavity/bump/SSS changes on shaders. This is really nice to work with (especially with SSS I've been waiting for ages) . 8 Share this post Link to post Share on other sites
ajz3d 786 Report post Posted March 28, 2016 Is there way to reproduce? Or send me scene. I succeeded in reproducing the bug every time with my scene. The issue appears to be caused by Apply Symmetry to Current Layer. Before I use this operation on a currently selected retopo group, all UVs from a current UV set unwrap correctly. However if I apply the symmetry, it affects other retopo groups from a given UV set by "fragmenting" their UVs. Seams created this way cannot be removed neither by Mark Seams nor Clear Seams tools, so the corruption is permanent, and the only remedy is to reload either the full scene or overwrite affected retopo groups with their backups. https://www.dropbox.com/s/y1wozo7ctkfrhtt/uv_fragmentation_bug.mp4?dl=1 Share this post Link to post Share on other sites
ajz3d 786 Report post Posted March 28, 2016 (edited) Andrew, sculpt shaders cannot be applied to VoxTree layers from older .3b files. Those layers need to be converted to voxels or reimported into the tree first. Could you please do something about it? Edited March 28, 2016 by ajz3d Share this post Link to post Share on other sites
ajz3d 786 Report post Posted March 28, 2016 I succeeded in reproducing the bug every time with my scene. The issue appears to be caused by Apply Symmetry to Current Layer. Before I use this operation on a currently selected retopo group, all UVs from a current UV set unwrap correctly. However if I apply the symmetry, it affects other retopo groups from a given UV set by "fragmenting" their UVs. Seams created this way cannot be removed neither by Mark Seams nor Clear Seams tools, so the corruption is permanent, and the only remedy is to reload either the full scene or overwrite affected retopo groups with their backups. https://www.dropbox.com/s/y1wozo7ctkfrhtt/uv_fragmentation_bug.mp4?dl=1 Update: This is NOT limited to a single UV set. What I did just a moment ago was that I moved my current retopo group to a separate UV set, applied symmetry to it, and what I found out is that the retopo group, that was previously on the same UV set, got corrupted. Andrew, I'll send you the scene. I'll just have to shrink it down a bit because it's over 1GB. Share this post Link to post Share on other sites
ajz3d 786 Report post Posted March 28, 2016 (edited) Andrew, I sent you an e-mail regarding that UV (and geo) issue. --- @Beat, top notch "doodles". Jolly good show! --- REGRESSION: Andrew, the red circle manipulator that is used for determining a sphere primitive's diameter... It does not work in 4.5.33. To reproduce, enter Primitives tool and select a sphere. Grab the red circle and resize it. Edited March 28, 2016 by ajz3d 1 Share this post Link to post Share on other sites
PixelDust 17 Report post Posted March 28, 2016 Looks good, BeatKitano! What shader are you using there, and what did you find out about how to use SSS? All I could figure out is that you have to have "use normalmap texture" checked to get the SSS setting to show up. I may confirm this soon. Started doodling to test the new cavity/bump/SSS changes on shaders. This is really nice to work with (especially with SSS I've been waiting for ages) . Share this post Link to post Share on other sites
AbnRanger 1,537 Report post Posted March 29, 2016 Looks good, BeatKitano! What shader are you using there, and what did you find out about how to use SSS? All I could figure out is that you have to have "use normalmap texture" checked to get the SSS setting to show up. Use the SKIN shader. It's different than the others, and isn't reliant on normal map information, You won't see the SSS effect in the Sculpt Room workspace...only in the Render room, when you click on RENDER or the Realtime Render button. 1 Share this post Link to post Share on other sites
ajz3d 786 Report post Posted March 29, 2016 (edited) You won't see the SSS effect in the Sculpt Room workspace...only in the Render room, when you click on RENDER or the Realtime Render button. You can enable Cast Shadows in the sculpt room for a rough SSS approximation. Edited March 29, 2016 by ajz3d Share this post Link to post Share on other sites
gbball 200 Report post Posted March 29, 2016 Glad to see you back Beatkitano! 1 Share this post Link to post Share on other sites
ajz3d 786 Report post Posted March 29, 2016 (edited) Andrew, I'm having a very hard time working with radial symmetry in the retopo room. I have symmetry set to radial on Z-axis and order of 6 and it constantly falls out of synchronization when I create new geometry. What's more, when I hit the Apply Symmetry to Current Layer, it removes a lot of faces from my retopo group and stacks polygons on top of each other, creating a very dirty topology! It's impossible to work with radial symmetry ATM. --- I sent you an e-mail regarding this issue. Edited March 29, 2016 by ajz3d Share this post Link to post Share on other sites
PixelDust 17 Report post Posted March 29, 2016 Use the SKIN shader. It's different than the others, and isn't reliant on normal map information, You won't see the SSS effect in the Sculpt Room workspace...only in the Render room, when you click on RENDER or the Realtime Render button. Thanks! The only skin shader I seem to have is a PBR shader in the paint room, though. I had made a sculpt shader called "Skin" earlier - could that have messed things up? Share this post Link to post Share on other sites
ajz3d 786 Report post Posted March 29, 2016 (edited) Thanks! The only skin shader I seem to have is a PBR shader in the paint room, though. I had made a sculpt shader called "Skin" earlier - could that have messed things up? Are you sure that you have 3D-Coat version 4.5.33 installed? It has two main sculpt shaders. The new PBR one, which supports SSS among other stuff, and a legacy PicMat one (now called a MatCap). Edited March 29, 2016 by ajz3d 1 Share this post Link to post Share on other sites
PixelDust 17 Report post Posted March 29, 2016 (edited) Are you sure that you have 3D-Coat version 4.5.33 installed? It has two main sculpt shaders. The new PBR one, which supports SSS among other stuff, and a legacy PicMat one (now called a MatCap). I renamed my old 4.5 user folder and reinstalled, and I see a skin shader now - thanks. Edited March 29, 2016 by PixelDust 1 Share this post Link to post Share on other sites
ajz3d 786 Report post Posted March 29, 2016 (edited) It says I have 4.5.33 installed. I did do a system restore earlier today, so I may have to reinstall 3D-Coat. Okay, so In sculpt room shaders you should have one called "skin". It has SSS enabled by default and is preconfigured to act as a human skin shader. Edited March 29, 2016 by ajz3d 2 Share this post Link to post Share on other sites
Taros 370 Report post Posted March 29, 2016 New face/vertex extrude: We need a value input field for the extrusion distance like in vox layer. (Important for exact extrusion distance when working with technical parts) Thank you Chris 1 Share this post Link to post Share on other sites
Taros 370 Report post Posted March 29, 2016 Factures: Normalmap values from facture shaders look wrong after baking into paint room. Unfortunately I must switch facture normalmaps off at the moment before bake process. Share this post Link to post Share on other sites
insignet 44 Report post Posted March 29, 2016 (edited) Quick test using the standard sss shader... thrown into render room, instant results. Great work. Edited March 29, 2016 by insignet Share this post Link to post Share on other sites
