ajz3d 786 Report post Posted March 6, 2015 Great job Andrew! I have a question. What exactly does the new AO_Intensity parameter represent? Its low values almost completely remove the diffuse (if no additional lights are present in the scene), and at 100% the diffuse contribution increases to very saturated colour levels - much more saturated from what is displayed in the normal viewport. Share this post Link to post Share on other sites
JoseConseco 122 Report post Posted March 6, 2015 Thanks for update. Can you guys open old files in beta13? For me 3dc freezes. And once I managed to open old file, but specular information was lost Share this post Link to post Share on other sites
AbnRanger 1,537 Report post Posted March 6, 2015 Thanks for update. Can you guys open old files in beta13? For me 3dc freezes. And once I managed to open old file, but specular information was lost I've been having real trouble doing so. There is something wrong with this build. Files I was just working on today, won't open. Was able to get another file open, but it seems to take way too long to open...nearly 2-3minutes. Share this post Link to post Share on other sites
ajz3d 786 Report post Posted March 6, 2015 (edited) On my system I can open files and nothing appears to be lost. Also, opening files takes the same amount of time as usual. Have you guys tried with factory settings? I do however have other problem with this build. The freeze tool inside the paint room no longer displays frozen stuff. Toggling freeze view or Show/Hide Freeze doesn't help much. Frozen surface is no longer distinguishable from unfrozen. --- http://3d-coat.com/mantis/view.php?id=1810 Edited March 6, 2015 by ajz3d Share this post Link to post Share on other sites
JoseConseco 122 Report post Posted March 6, 2015 AbnRanger, yep they load but very long time. ajz3d - i can confirm this in uv mode. Also I found a possible reason why 'on plane' won't work with LC General brush. It would be great if you could +1 to this http://3d-coat.com/mantis/view.php?id=1809 1 Share this post Link to post Share on other sites
ajz3d 786 Report post Posted March 6, 2015 (edited) ajz3d - i can confirm this in uv mode. Indeed, it works fine when vertex painting. It's the UV mode that doesn't work any more. Thanks for the info. Edited March 6, 2015 by ajz3d Share this post Link to post Share on other sites
Javis 523 Report post Posted March 6, 2015 BETA13 - Finished render room update, rendering using panorama lights supported! - Undo lag on highpoly objects fixed - Fixed problem of "parasite" background transparency inside semitransparant controls/guides in incremental render mode. - Possibility to open Autosave directly from File menu. - UV mapping currected, v-direction flipped - Blur/sharpen panorama control in navi bar - Color transformations will not be applied to normalmap layer in "Apply to al" mode. - Crash related to vertex painting and undo fixed. - Space panel size decreased even more. - Problem of saving Vox Hide hidden data solved. How all may be restored after reopening the scene. - Broken small-scale curves problem fixes - ggx supported very well! - Export of AO/curvature in unified export dialog - Draw on plane option got additional constraints - XY,YZ and ZX planes. Thanks for your hard work Andrew! I'm downloading now, looking forward to checking this build out. Share this post Link to post Share on other sites
Carlosan 2,463 Report post Posted March 7, 2015 - What exactly does Render Light for Panorama on/off ? - Adjust Primary Light Intensity vs Exposition ? Which value is correct ? Left PLI = 14 / E = 300 < ------------ > Right PLI = 294 / E = 14 any help is welcome ty 1 Share this post Link to post Share on other sites
ajz3d 786 Report post Posted March 7, 2015 - What exactly does Render Light for Panorama on/off ? - Adjust Primary Light Intensity vs Exposition ? Which value is correct ? Left PLI = 14 / E = 300 < ------------ > Right PLI = 294 / E = 14 14-300.jpg 294-14.jpg any help is welcome ty I was asking myself the same questions. Share this post Link to post Share on other sites
Andrew Shpagin 1,463 Report post Posted March 7, 2015 Thats awesome! But wait, month after month goes by and still no Mac/Linux versions? We're starting to feel a little abandoned, just a teeny-weeny tiny little bit..Mac/linux porting code on higher version of GL finished. The only rest thing - correcting all shaders. This is small in comparison to all big job. Generally all that problems are because of textureLod instruction in shaders and how Apple treats programmers job... Share this post Link to post Share on other sites
Javis 523 Report post Posted March 7, 2015 Don't sweat it too much Andrew. Patience is a Virtue lost in this era. Everyone will get their mac and Linux in due course. In the mean time, there is some serious loading issues in build 4.5.13. Even small files can take a while to load, while my larger files can take a very long time. As in minutes, one sculpture I recently did takes almost 10 minutes to load. Share this post Link to post Share on other sites
red2blue 3 Report post Posted March 7, 2015 Do I have to uninstall the old Beta, or can I just install the new one over the old one?Thanks! Share this post Link to post Share on other sites
BeatKitano 321 Report post Posted March 7, 2015 You can overwrite. Share this post Link to post Share on other sites
red2blue 3 Report post Posted March 7, 2015 You can overwrite. Thanks, I will give it a try! Share this post Link to post Share on other sites
Metromot 1 Report post Posted March 7, 2015 Don't sweat it too much Andrew. Patience is a Virtue lost in this era. Everyone will get their mac and Linux in due course. I apologize if anyone feels there is too much impatience about Mac/Linux versions being expressed here. I am confident Andrew does the right thing but the last time we heard about it was back in January and we are all anxious to see it. Share this post Link to post Share on other sites
Andrew Shpagin 1,463 Report post Posted March 7, 2015 Don't sweat it too much Andrew. Patience is a Virtue lost in this era. Everyone will get their mac and Linux in due course. In the mean time, there is some serious loading issues in build 4.5.13. Even small files can take a while to load, while my larger files can take a very long time. As in minutes, one sculpture I recently did takes almost 10 minutes to load. If you have any file that loads long - please drop it to me. It will help a lot. Share this post Link to post Share on other sites
AbnRanger 1,537 Report post Posted March 7, 2015 If you have any file that loads long - please drop it to me. It will help a lot. Andrew, all files I try to load take longer. MUCH longer. You can probably load some files in Beta 12 and then install Beta 13 and time how long it takes to load. Big difference. Share this post Link to post Share on other sites
JoseConseco 122 Report post Posted March 7, 2015 (edited) Actually I have file without polypaint that is loading quite fast. So maybe reading vertex color data is slowing down of loading of file.. Edited March 7, 2015 by JoseConseco Share this post Link to post Share on other sites
Andrew Shpagin 1,463 Report post Posted March 7, 2015 Please send me any slow file. All my files open really quickly. I see no difference with 12 build on my tests. Share this post Link to post Share on other sites
JoseConseco 122 Report post Posted March 7, 2015 I have sent you a PM with example scene that loads above 5min (I didn't wait till the end ) Share this post Link to post Share on other sites
AbnRanger 1,537 Report post Posted March 7, 2015 I have sent you a PM with example scene that loads above 5min (I didn't wait till the end ) Yeah, I've got one that for whatever reason is 3 freaking GBs...and it's just a bust using LiveClay. It took about 1.5min to load with Beta 12, but even after 15 minutes it still hasn't loaded. uploading it now Share this post Link to post Share on other sites
alvordr 104 Report post Posted March 7, 2015 Wow. The size of the beta is now at over 1/2 Gb. That's a big jump from before. Share this post Link to post Share on other sites
alvordr 104 Report post Posted March 7, 2015 (edited) Hey, Andrew. Great work on the Render Room! I'm happy to see it getting some love. It's probably one of the lowest priorities I see for the program, but it is a significant jump from where it was. It would be helpful to have a toggle that allows for showing of the sculpt vs the painted and/or retopo'd mesh in the render room. You can do this, but it seems to require hiding all of the layers to show just the sculpt. I did notice slower load times, as well. Having said that, it wasn't horrible...but I did just upgrade to an SSD. I did notice that rotating the scene around is more laggy than normal. It's not as smooth. Edited March 7, 2015 by alvordr Share this post Link to post Share on other sites
alvordr 104 Report post Posted March 7, 2015 I brought this up before, but it would be great to be able to rotate the light vertically, as we used to, instead of just horizontally. 1 Share this post Link to post Share on other sites
AbnRanger 1,537 Report post Posted March 7, 2015 This file was opened at 7:59am...it's 9:15am and it STILL hasn't loaded! Share this post Link to post Share on other sites
