Member Quizzicall Posted December 23, 2014 Member Report Share Posted December 23, 2014 I was just wondering what is the best and easiest way to lower the poly count? I know there is the Resample and the whole thing with Surface mode but like I said what is the best way to do it? Quote Link to comment Share on other sites More sharing options...
Contributor Solution Malo Posted December 23, 2014 Contributor Solution Report Share Posted December 23, 2014 The best way is to do it by hand. Surface mode and the Clean Clay Tool do the trick. Reduce the polys only in that areas that are needed, without loosing dedails. If it makes no difference if you loose details, then it would be easier if you resample your model. Quote Link to comment Share on other sites More sharing options...
