Vaiktorg
Hidden Geometry From Layer Wont Delete
Ok so i manage to make a simple mesh and separated everything so that i can now start sculpting BUT! i came into this problem! I dicided the "organic part" of the model, from the metal ones. Now, when i try to sculpt over the place where the blade should be, part of the blade appears, so i thought to myself, probably i hvnt deleted the hidden geometry! ok, so i went to Geometry > Delete Hidden and went ahead to sculpt.... NOP! the blade's hidden geometry is still there!
141956748312.jpg10885445_10204385742901043_1699876028714
Hi Vaiktorg
You mean Ghost Mode on/ off ?
post-10142-0-52071400-1419594877_thumb.j
If you can see in the image, i have various parts removed from the sword, and divided them into layers with the use of the "separate from hidden". They're supposed to be different meshes. I made the other layers in ghost mode so that i can have a visual representation where should i move the geometry over the other pieces. But it seems that there is still hidden geometry on the sword handle, where the blade should go.
Using Beta 2: same trouble ?
To press the eye icon to put that layers off, helps ?
*sorry, cant see exactly the geometry in the images
It kind of magically repaired it self ._. cuz i (sadly) re-did the work lol but i really dont know how or why this happened.
