Member mlogan Posted December 29, 2014 Member Report Share Posted December 29, 2014 Hi there, A new user question. I use Lightwave, Blender and Zbrush. I find the UI and workflow of Zbrush extremely frustrating and unintuitive. 3d Coat looks much more logical to me. One question: does 3D Coat have a radial brush? I'm looking but not finding one. If not, that's a bummer as I would prefer to stay just in 3D Coat, rather than skipping back to Zbrush. Other than that, it all looks really promising. Any responses are much appreciated. regards Mike Quote Link to comment Share on other sites More sharing options...
Javis Posted December 29, 2014 Report Share Posted December 29, 2014 Hi, I haven't used ZB in a long time. Could you tell me what the radial brush does so I can find the equivalent for you? And welcome aboard! Glad to have you here. Quote Link to comment Share on other sites More sharing options...
Member mlogan Posted December 30, 2014 Author Member Report Share Posted December 30, 2014 Hi Javis, Say you had a hexagonal lamp post and you wanted to add the same detail to each face of the post. You could individually sculpt the detail on each face and try to make them look as similar as possible. Or with Zbrush's radial brush you could turn on 6 axes of symmetry and sculpt on one face of the post and it would do the same on the other 5 faces. Great time saver. Thanks for your help. regards Mike Quote Link to comment Share on other sites More sharing options...
Contributor Solution Malo Posted December 30, 2014 Contributor Solution Report Share Posted December 30, 2014 Turn on symmetry. There are some options for radial symmetry. This should helps you. Quote Link to comment Share on other sites More sharing options...
