[Solved] Mirroring in Voxel room ?
nirsul
Hi all
Isn;t there a mirror tool in the voxel room ? I am trying something like the mirror and weld in ZBrush but cannot work it out - Tried the "Apply" Axial Symmetry" but cant understand the logic of it - tried typing various logical numbers but all fail to perform a simple mirror.... :-(
NIR
Under the Voxels menu (top tool bar) select Symm Copy.
If the wrong side gets copied then use the smooth brush set at zero depth just to touch the side that you want to mirror. Now 3DCoat knows which side to mirror to...
You can define a Hot Key for this action as well.
Edited by digman
I often hover over the side I want to copy from and hit the "H" key (which Picks the object)....it's a good way to tell 3D Coat which side you are copying from, too. Chris goes into the topic in a bit of detail, here:
  • 3 years later...
Since this post comes up in a Google Search for Mirroring in the Voxel room, is there an easy way to simply mirror a Voxel mesh without doing Symcopy? Sometimes you want a mirrored version of the mesh instead of rotating it and I can't find a way to just mirror it.
Thanks!
Oh, I also wanted to mention that Symm Copy is now in the Geometry menu in 3DC 4.8.20
Edited by TorQueMoD
