probiner
Is there a trade of with voxels and pixel paint when it comes to PBR?
Seems to me that voxels paint doesn't show normal/height displacement and that pixel pain doesn't show reflections but just colored spec.
Is this true? There's no way to see all channels at play yet?
pixel pain does relief: http://prntscr.com/5pl5dn
voxel paint does reflections: http://prntscr.com/5pl6pr (relief channel always empty)
Can't have both though... -_-'
Sorry if this is known, first time I tested 3DC PBR.
Cheers
Edited by probiner
You could paint your fine details as high/normalmap in Paint Room after baking on your Lowpoly.
It is not neccessary to do everything in your highpoly.
just load an environment map,per pixel painting reflectivity works fine.
Depth painting in SF mode is on Andrew's to do list.
I stand corrected. Voxels were being scaled and so the density made the material look different. Indeed reflections are working with pixel paint.
I supposer SF mode is Voxels? If yes, ok I see, thanks.
Surface mode is polygons, Voxel mode is voxels.
Ah, ok, true,I though it used to be called Voxel Room  :) But you're right, the tricky part is that Voxels are converted to Surface on the fly when you go to the paint room. Had no idea.
Anyways, I was looking forward more for per pixel painting relief, since it captures details better than SF vertex paint.
Plus I noticed that the cavity map generated for dense SF isn't that useful for PBR painting: http://prntscr.com/5ptv1s
Thanks
Where do I actually load these maps by the way?
Thanks
Edited by probiner
