Reputable Contributor digman Posted February 2, 2016 Reputable Contributor Report Share Posted February 2, 2016 (edited) This goes with the above post... One reason to match to the 3DC rendering (Render Room) is it helps me judge how the material is responding to said light and environment in Cycles. I generally desire the same reflective qualities to be in the Cycles render that I see in the 3DC smart material. I need to adjust the roughness map as Cycles roughness through the PBR shader node that I like to use is not as reflective as in 3DC. I use the same Environmental Hdr. Once tweaking the roughness map, I no longer need to reference 3DC... Tweaking the albedo and normal map is an artistic call... Metal map needs no tweaking... Edited February 2, 2016 by digman Quote Link to comment Share on other sites More sharing options...
Taros Posted February 3, 2016 Report Share Posted February 3, 2016 You can always improve your cycles render result by using a postpro effect. The point is how the renderer handles the colors. There is a difference between all renderers. It is the main reason why artists prefer one solution more than others. And don't forget the realtime antialiasing. 3D-Coat handles this rudimentary at the moment. PS: A good article by Brent Burley by the way. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted February 3, 2016 Reputable Contributor Report Share Posted February 3, 2016 (edited) I like the richness of the colors that Blender produces in the renders, which of course can be made better or adjusted through compositing... Today I started to work on the Glossness--Specluar Color workflow from 3DC to Blender, no PBR node shader needed. Here are two results of the testing so far... 1000 samples....Cycles... Fantasy metals covered with a dielectric material The one on the right is duller and has the same reflective qualities as in 3DC. Sometime this year, I will add Houdini to my workflow. Once done with both workflows, I will make 2 videos. One for each workflow... Edited February 3, 2016 by digman 1 Quote Link to comment Share on other sites More sharing options...
Moderator Daniel Posted February 4, 2016 Moderator Report Share Posted February 4, 2016 Guys, glad to know you are searching for the best result. I agree with Taros that Cycles gives more true (truer?) picture as it uses ray tracing, etc. + anti-aliasing making it look not as crisp as in 3dc's viewport. For me, I'm totally happy with the Cycles results (after tweaking Roughness RGB curve). BTW for my above pictures I used 50-64 samples Malo, could you give me that gun with textures for tests??? ) Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted February 4, 2016 Reputable Contributor Report Share Posted February 4, 2016 (edited) Guys, glad to know you are searching for a best result. I agree with Taros that Cycles gives more true (truer?) picture as it uses ray tracing, etc. + anti-aliasing making it look not as crisp as in 3dc's viewport. For me, I'm totally happy with the Cycles results (after tweaking Roughness RGB curve). BTW for my above pictures I used 50-64 samples Malo, could you give me that gun with textures for tests??? ) Oh, I like beating my images over the head with Samples! The Glossness---specular color workflow I am working on is for 3DC users who do not what to go the PBR node route using the roughness---metalness workflow... I am quite pleased that both workflows work well... Edited February 4, 2016 by digman Quote Link to comment Share on other sites More sharing options...
Moderator Daniel Posted February 4, 2016 Moderator Report Share Posted February 4, 2016 AFAIK, PBR in 3DC is being tweaked right now, so I suggest you no rush Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted February 4, 2016 Reputable Contributor Report Share Posted February 4, 2016 Oh! Then I will put the brakes on... and will be waiting to see these lovely tweaks... Quote Link to comment Share on other sites More sharing options...
Moderator Daniel Posted February 11, 2016 Moderator Report Share Posted February 11, 2016 2 cents: IOR for metalls should be 1.0 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted February 14, 2016 Reputable Contributor Report Share Posted February 14, 2016 AFAIK, PBR in 3DC is being tweaked right now, so I suggest you no rush I put the tutorials on hold, so hopefully the tweaking will be done soon and a new PBR update will be around the corner... Quote Link to comment Share on other sites More sharing options...
PolyHertz Posted February 15, 2016 Report Share Posted February 15, 2016 Has anything been said about what will be a part of the PBR update? SSS material support perhaps? Quote Link to comment Share on other sites More sharing options...
