Advanced Member worldcrafter Posted January 22, 2015 Advanced Member Share Posted January 22, 2015 Hello, can a fellow mud-box user tell me how i export a high poly mesh from 3DC to mud box with correct topology? (so i am able to subdivide it in mudbox) Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17266-solved-3dc-to-mudbox/ Share on other sites More sharing options...
Contributor Malo Posted January 23, 2015 Contributor Share Posted January 23, 2015 Have you tried the Quadmesh export? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17266-solved-3dc-to-mudbox/#findComment-117814 Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 23, 2015 Reputable Contributor Share Posted January 23, 2015 Hello, can a fellow mud-box user tell me how i export a high poly mesh from 3DC to mud box with correct topology? (so i am able to subdivide it in mudbox) I would try to retopo the mesh > UV unwrap > export the mesh and the displacement map...which you can load in MB. If you Retopo the model > bake to MicroVertex mode, you can export a dense mesh with the displacement baked right into the exported mesh. No need to even load a displacement map in MB, if you go that route. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17266-solved-3dc-to-mudbox/#findComment-117816 Share on other sites More sharing options...
Advanced Member worldcrafter Posted January 24, 2015 Author Advanced Member Share Posted January 24, 2015 I would prefer not having to retopo and uv the mesh. Malo, what do you mean by quadmesh export? do you mean export dense quads? because that still produces mesh errors in mudbox. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17266-solved-3dc-to-mudbox/#findComment-117911 Share on other sites More sharing options...
Contributor Malo Posted January 24, 2015 Contributor Share Posted January 24, 2015 Yes, i mean Dense Quad or Project Quads. Both makes Quads but slightly different. But i think ABN is right. Retopo would be much better for you. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17266-solved-3dc-to-mudbox/#findComment-117914 Share on other sites More sharing options...
Advanced Member worldcrafter Posted January 24, 2015 Author Advanced Member Share Posted January 24, 2015 (edited) that's a real shame Perhaps someone knows a program that can decimate the model to work with mudbox... will try meshlab but any other suggestions would be good Edited January 24, 2015 by worldcrafter Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17266-solved-3dc-to-mudbox/#findComment-117919 Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 25, 2015 Reputable Contributor Share Posted January 25, 2015 that's a real shame Perhaps someone knows a program that can decimate the model to work with mudbox... will try meshlab but any other suggestions would be good Raul is working on a new Quad-Meshing routine, so that might be a solution in the near future. I hope it will be available by the time 4.5 is officially released. https://farsthary.wordpress.com/ Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17266-solved-3dc-to-mudbox/#findComment-117937 Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 25, 2015 Reputable Contributor Share Posted January 25, 2015 And even though you may not want to do any retopology, as with any app, you have to play by it's rules. Hi-res sculpting in 3D Coat is either voxels or a dense collection of triangles. You want to force 3D Coat to export quads straight from a dense mesh made up of triangles, when it's not designed to do that. Even in Mudbox, it's sometimes necessary to retopologize, so get out of the habit of wanting to take shortcuts for everything. We all want to be more efficient and minimize tedious tasks, but being to bent on taking the automated way of doing things will lead to poor results more often than not. That's why I use the Strokes tool and other manual retopo tools 80% of the time. Auto-Retopo is great in many cases, but it's not the best solution in many others. You could hide the head of a character and Auto-Retopo the body, while using Manual Retopology for the head. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17266-solved-3dc-to-mudbox/#findComment-117938 Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 25, 2015 Reputable Contributor Share Posted January 25, 2015 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17266-solved-3dc-to-mudbox/#findComment-117939 Share on other sites More sharing options...
Advanced Member worldcrafter Posted January 25, 2015 Author Advanced Member Share Posted January 25, 2015 I would have never expected the autopo in mudbox to work on mesh's with "errors" but it does! takes 10 mins to process and autopo a high poly model in mudbox, but i guess that cant be helped. SOLVED Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17266-solved-3dc-to-mudbox/#findComment-117975 Share on other sites More sharing options...
