Member curvedspace Posted February 13, 2015 Member Report Share Posted February 13, 2015 Hi, I am a newcomer to 3D-Coat, though not to 3D. There are a few questions I have, so I will start with the first one:Is there a tool in 3DC that measures wall thickness? Quote Link to comment Share on other sites More sharing options...
Javis Posted February 13, 2015 Report Share Posted February 13, 2015 Hi! If you're in the Sculpt Room, there is a measuring tool that you could use to measure distance. Though it wont give you exact measurements, it'll be pretty close. Quote Link to comment Share on other sites More sharing options...
Advanced Member Solution arumiat Posted February 15, 2015 Advanced Member Solution Report Share Posted February 15, 2015 If you were wanting to define a wall thickness this thread has some useful points. Relies on a single layer surface mesh though.. Quote Link to comment Share on other sites More sharing options...
Member curvedspace Posted February 16, 2015 Author Member Report Share Posted February 16, 2015 Thank you. I was hoping there was a tool were just by touching the surface it would give a thickness reading. But this is fine. Quote Link to comment Share on other sites More sharing options...
