Member Sorin Posted March 2, 2015 Member Report Share Posted March 2, 2015 I can't see the model (mesh) in 3D view of 3D Coat V4.5 (beta) , i ca see just the background and the grid. But 3D Coat V4 works just fine . Can you help me? I really want to test the PBR Materials. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted March 2, 2015 Report Share Posted March 2, 2015 Is it a model in the painting room or something you sculpted? I don't have 3DC in front of me but make sure layer 0 is not hidden in the paint room and any object layers too. I'll double check what I'm saying when I get home. Quote Link to comment Share on other sites More sharing options...
Member Sorin Posted March 3, 2015 Author Member Report Share Posted March 3, 2015 I've tried with all the default models and with models made by me , and i've checked if they are hidden but they are not. This is a print screen with 3d coat. You can see that in the UV Map the model exists but i can't see it in the 3D View. I can't paint , Tweak , Sculpt etc. I can't do nothing because i don't see the model in 3d View. Quote Link to comment Share on other sites More sharing options...
Contributor BeatKitano Posted March 3, 2015 Contributor Report Share Posted March 3, 2015 First try pressing frame all the [ALL] button in the navigator bar over the viewport. Second: make sure there's some paint on the layer 0 Even basic color, otherwise it's considered all transparent and you won't see your model. Quote Link to comment Share on other sites More sharing options...
Member Sorin Posted March 3, 2015 Author Member Report Share Posted March 3, 2015 I've pressed the [ALL] button and applied some paint on Layer 0. This is how it's looking now. Quote Link to comment Share on other sites More sharing options...
Contributor BeatKitano Posted March 3, 2015 Contributor Report Share Posted March 3, 2015 Can you try deactivating backface culling in view menu ? Quote Link to comment Share on other sites More sharing options...
Member Sorin Posted March 3, 2015 Author Member Report Share Posted March 3, 2015 (edited) Nothing changed... I want to remember you that the 3D Coat V4 it's working fine i have problems just with the V4.5 Beta. I just saw that if i activate the "Wireframe" from the View menu i can see the 3D model wireframe but i still can't see the textures... Edited March 3, 2015 by Sorin Quote Link to comment Share on other sites More sharing options...
Contributor BeatKitano Posted March 3, 2015 Contributor Report Share Posted March 3, 2015 Ok then submit a bug report to mantis. Andrew will probably check this thread since it's in the urgent section. Sorry for not being of much help here. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 3, 2015 Report Share Posted March 3, 2015 Hi If at Paint Room you press W, anything is show ? Will you please add an UVROOM screen capture ? Could you please attach any model made by you ? Quote Link to comment Share on other sites More sharing options...
Member Sorin Posted March 3, 2015 Author Member Report Share Posted March 3, 2015 If i press W i can see the model wireframe. This is the screen capture of the UV Room : And this is the 3D Model. http://www.girlshare.ro/34519595 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 3, 2015 Report Share Posted March 3, 2015 Material have a texture empty, no poly assigned Spartan_Sword is ok please delete Material, export .obj and import for PPP again //edit there is a Blender applink that help to go back and for. Quote Link to comment Share on other sites More sharing options...
Member Sorin Posted March 3, 2015 Author Member Report Share Posted March 3, 2015 I've deleted the material and exported as an .obj and imported it in to 3D Coat for PPP , but the same thing happens i can't see the texture only the wireframe if i press W. This is happening even with the 3D Coat models. In the 3D Coat V4 my model and the 3D Coat models works fine i can see them , i can paint , i can sculpt i can do everything but the 3D Coat V4 doesn't have the PBR Materials and that's why i want to make them work in 3D Coat v4.5 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 3, 2015 Report Share Posted March 3, 2015 could we try another way ? - uninstall 3DC - delete ALL 3dc directories before re-installing - manually remove the 3DC folder under Documents/settings* you will have to re-register your serial number again by removing that folder *ty digman Quote Link to comment Share on other sites More sharing options...
Member Sorin Posted March 3, 2015 Author Member Report Share Posted March 3, 2015 (edited) Still the same problem... Edited March 3, 2015 by Sorin Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 3, 2015 Report Share Posted March 3, 2015 using this model... same problem ? SW.7z Quote Link to comment Share on other sites More sharing options...
Contributor Malo Posted March 3, 2015 Contributor Report Share Posted March 3, 2015 @Sorin Looks like there is still something wrong with your install. If i use your obj file, i have no problems. Quote Link to comment Share on other sites More sharing options...
Member Sorin Posted March 3, 2015 Author Member Report Share Posted March 3, 2015 I know it's something with 3D Coat v4.5 Beta . In 3DC v4.5 beta i can see just the wireframe but in 3DC v4 i can do everything , it's working fine as you can see in the images below. V4.5 Beta. V4. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 3, 2015 Report Share Posted March 3, 2015 try this set please Quote Link to comment Share on other sites More sharing options...
Member Sorin Posted March 3, 2015 Author Member Report Share Posted March 3, 2015 (edited) Nope , the same . It just want to work... Edited March 3, 2015 by Sorin Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 3, 2015 Report Share Posted March 3, 2015 if you import this .dae model -without any .mtl- SpartanSword.7z same problem ? ------------------------------------------------------------------------ - if yes: Send a support-related question, to Andrew Shpagin at support@3d-coat.com ty Quote Link to comment Share on other sites More sharing options...
Member Sorin Posted March 3, 2015 Author Member Report Share Posted March 3, 2015 ok , i will try Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 3, 2015 Report Share Posted March 3, 2015 dae model added Quote Link to comment Share on other sites More sharing options...
Member Sorin Posted March 3, 2015 Author Member Report Share Posted March 3, 2015 Yes the same problem , i've send an e-mail to Andrew . Ty for your help. Quote Link to comment Share on other sites More sharing options...
