New Member SavannaW Posted March 10, 2015 New Member Share Posted March 10, 2015 Hi! I'm new to 3D Coat, and am currently using the 30 day trial on a 64-bit Windows 7 computer. I really like the program so far, but I'm having a problem. I can't see any of the files related to it in Windows Explorer. I can't find 3D Coat itself or any files I save or export from it under Program Files, Documents, not anywhere. It doesn't show up in All Programs or in Add/Remove Programs in the control panel. I found and turned off "hide hidden folders" on my computer, and that didn't reveal it. To run the program, I have to run setup again. But it saves and remembers my previous files, so it's not like things are getting deleted. When in 3D Coat's Save or Open windows, I can see the 3D Coat program files and all my saves/exports. But when I go to those same locations from outside 3D Coat, I can't find those folders and files. If anyone could help me with this I'd very much appreciate it. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17506-cant-find-3d-coat-files-in-windows-explorer/ Share on other sites More sharing options...
Carlosan Posted March 10, 2015 Share Posted March 10, 2015 Hi! All the files are in C:\Users\username\Documents\3D-CoatV4 Hope it help 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17506-cant-find-3d-coat-files-in-windows-explorer/#findComment-119996 Share on other sites More sharing options...
New Member SavannaW Posted March 10, 2015 Author New Member Share Posted March 10, 2015 Hi Carlosan, thanks for trying to help! Unfortunately, I can't see the 3D Coat folder there, either. I restarted the computer and checked again, but still nothing there. I used the search on my computer, and all it finds is the 3D Coat install file in my downloads. Yet when I go to install 3D Coat (for the fourth time) a folder for it already exists (from one of the last three times). It's the weirdest thing. It's like it exists, but is hidden from both me and my computer's search. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17506-cant-find-3d-coat-files-in-windows-explorer/#findComment-120006 Share on other sites More sharing options...
Contributor Solution Michaelgdrs Posted March 10, 2015 Contributor Solution Share Posted March 10, 2015 Unistall and re install using Admin. (right click run as administrator) Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17506-cant-find-3d-coat-files-in-windows-explorer/#findComment-120011 Share on other sites More sharing options...
New Member SavannaW Posted March 10, 2015 Author New Member Share Posted March 10, 2015 Thank you, Michaelgdrs, that did it! 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17506-cant-find-3d-coat-files-in-windows-explorer/#findComment-120015 Share on other sites More sharing options...
Contributor Michaelgdrs Posted March 10, 2015 Contributor Share Posted March 10, 2015 Glad to know this , welcome to the community. 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/17506-cant-find-3d-coat-files-in-windows-explorer/#findComment-120016 Share on other sites More sharing options...
