3D Coat Forums
Carlosan
Unreal Engine - MASTER THREAD
Using Unreal Engine 4 for asset rendering.
by JoseConseco
It is not step by step tutorial how to setup your asset for rendering in Unreal Editor 4, but more of a help to get idea how simple  it is. UE4 options/buttons are self explanatory so I won’t be writing that ‘point light’ button is placing point light on scene.
unrealeditor4.jpg?w=640&h=359
Im making some assets for a game demo that im making in UE4, (btw carlosan there is no UDK anymore, now the main release is free!)
It's so easy with 3d-coat more than ever now with smart-materials   :rofl:
post-1920-0-55654500-1444269084_thumb.pn
Edited by ozukaru
For the best results in UE4:
  • Which maps should I export from 3D Coat?
  • How should I wire them up within Unreal's material editor?
Both of these seem like a no-brainer but I can't get it to look anywhere near as good as it does in 3D-Coat.
First, I am learning the game engine as well, not a guru here at all...
It appears you might need though I can not be sure. Check in your scene.
Sphere Reflection Capture. You need this to capture reflections correctly...
Lightmass Importance Volume. More protons are emitted inside this volume to have higher quality lighting inside this volume. Less Proton bounces are emitted outside this volume. The ElvenRuins level has this volume incasing the most important of the world. I then added a Sphere Reflection Capture so it inclosed my object. Shown in first picture. Second picture I did the same but a different scene.
Research these in the Unreal Documents.
I will continue this thread as I learn more myself.
Attached image: I was testing very shiny metal materials
3DC Settings:
GGX shader: Under the View menu
Roughness / Metalness workflow : Under the Texture / Texture Export / Import Workflow
Normal Map Preset set to Unreal in the Preferences Menu.
Maps Exported.
Albedo / Color
Roughness
Metalness  (do not put the roughness in the metalness alpha channel, that is for Unity 5)
Normal map
Edited by digman
  • Like 3
Ahh fantastic, I will have to try this out, I haven't opened up 3DC in ages but I'll defo try out those settings and do a test export myself :D
Is there a step by step like this?
The thing is its very straight forward. Only says the things that are relevant to the process. Doesn't make you watch him put all the materials together. All of the "heavy lifting" is done before he starts the video. Has anyone seen a tut like this? In 20 min he goes through the entire pipe.
There is multiple ways to get materials from 3D - Coat into UE4.
I am hoping to do some video tutorials soon using 3D - Coat and getting models and materials into UE4 as it is my engine of choice and 3D - Coat is the modelling program I will be using to produce my assets.
I just need to find the time. I may record myself doing the whole process from start to finish and edit it into a series I can put on Youtube, just to share the knowledge I have picked up. Will have to find the time to do it though, so don't rely on me haha :D
Unreal Engine 4.13 Released!
Unreal Engine 4.13 has been released and comes loaded with hundreds of updates as well as 145 contributions from the talented developer community via GitHub! This release contains huge additions to Sequencer such as import and export functionality, Alembic support for complex vertex animations, a brand new VR Template with baseline gameplay functionality and much more.
Hey,
how can i Scale the Export of FBX for UE4?
I use Millimeters (i think its better for weapons) in 3D Coat and the UE4 have 1uu = 1cm so when import the model it is to big and scale it to 0.01 then it is correct but that is shit with many models.
Someone an idea how you can adjust, so that you only once and then only export and everything fits.
1uu = 1cm -> so you have to use cm in 3DC and then the scale will be right.
Another way is to model a character and then build all assets around his scale -> so place it into 3DC - scale the mesh up - delete the size character.
- Your scene scale is ok ?
Hm,
I have make an 3d Model 1000 mm cube = 1 meter, then i changed to cm and it has 1000cm instead of 100cm. when i set the scene scale to 0.1 it works but the grid is a horror its to small
so thats not what i search, import it to blender end set the export to 0.1
https://seblagarde.wordpress.com/2014/04/14/dontnod-physically-based-rendering-chart-for-unreal-engine-4/
I get the permission from Dontnod entertainment to release the graphic chart I, Sophie Van de Velde (Lead environment) and Laurent Harduin (Lighter) made for the artists to help them with the physically based rendering (PBR) workflow present in the Unreal engine 4.
