New Member liyuchang Posted March 22, 2015 New Member Report Share Posted March 22, 2015 this is a simple quesiton but it really drives me crazy! I was shifted from maya for some reasons. In maya it is really easy to do these stuffs by just holding down W E R, but in 3D COAT I couldn't see any tool and key for this. Could you tell me how to "move", "rotate" and "scale" a object in a scene if I got multiple objects. Quote Link to comment Share on other sites More sharing options...
Advanced Member Solution arumiat Posted March 22, 2015 Advanced Member Solution Report Share Posted March 22, 2015 Sounds like you want to have a play with the transform tool 1 Quote Link to comment Share on other sites More sharing options...
New Member liyuchang Posted March 23, 2015 Author New Member Report Share Posted March 23, 2015 Sounds like you want to have a play with the transform tool transform.JPG Thanks for your reply, but there is another problem. How to select between objects if there are more than one object on the scene? when using transform tool, it moves all objects in the scene. Quote Link to comment Share on other sites More sharing options...
Advanced Member arumiat Posted March 23, 2015 Advanced Member Report Share Posted March 23, 2015 It sounds like these objects are on the same layer. When you bring objects into the scene you want to manipulate independently place them on a new layer. If you want to split the objects in your current scene an option is to use the 'split' tool Hope that helps Quote Link to comment Share on other sites More sharing options...
New Member liyuchang Posted March 23, 2015 Author New Member Report Share Posted March 23, 2015 It sounds like these objects are on the same layer. When you bring objects into the scene you want to manipulate independently place them on a new layer. Capture3.JPG If you want to split the objects in your current scene an option is to use the 'split' tool Capture4.JPG Hope that helps Thanks for your information. could you pls tell me how to assign current objects to a new layer? assume that there are two objects in the same layer, i would like to move one of the object to another layer in order to move that object. Quote Link to comment Share on other sites More sharing options...
Advanced Member arumiat Posted March 23, 2015 Advanced Member Report Share Posted March 23, 2015 One method is to A. Select split tool B. Hit E key and select the curvy circle thing C. Draw around the object you want to be separated D. This should place it on new layer Quote Link to comment Share on other sites More sharing options...
