Member AlphaGrunt Posted April 24, 2015 Member Report Share Posted April 24, 2015 This is just getting annoying....This used to work just fine but then I downloaded the beta version and overwrote my original copay of 3dcoat but have since re downloaded 4.1 So now when I import objects the "import to separate instances" no longer works!!! It goups everything together? I've tested this on other files I've imported without issue and they are all doing the same thing!? If I "import as child" it breaks the design down into a dozen or more pieces so I know it is recognizing the different materials upon import BUT the import to separate instances creates the root>volume>file name but puts the [2x] in front of the name as if I increased the resolution??? This makes no sense..can anyone advise on how to fix this? Quote Link to comment Share on other sites More sharing options...
Member AlphaGrunt Posted April 24, 2015 Author Member Report Share Posted April 24, 2015 (edited) Just wiped 3d coat from my computer thinking it was bugged since I have never had this issue before... Issue still remains. Can someone help me please. Edited April 24, 2015 by AlphaGrunt Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted April 24, 2015 Reputable Contributor Report Share Posted April 24, 2015 (edited) I edited my post, wrong answer on my part... Edited April 24, 2015 by digman Quote Link to comment Share on other sites More sharing options...
Member AlphaGrunt Posted April 24, 2015 Author Member Report Share Posted April 24, 2015 thanks anyway digman. Can anyone else please explain why this might be working this way/not working at all? Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted April 25, 2015 Contributor Report Share Posted April 25, 2015 Send the file to Andrew via support@3d-coat.com. Quote Link to comment Share on other sites More sharing options...
Member Solution AlphaGrunt Posted April 27, 2015 Author Member Solution Report Share Posted April 27, 2015 Got it sorted... Andrew pointed out that the name was changed from version 4.1.04-4.1.17 from "merge volumes" to "import as child".... I guess he said he might rename again to something more appropriate or change it back I don't know but regardless changing tool names over and over is never good from a user standpoint especially since this is now the 3rd name change for the same feature since V3.. Quote Link to comment Share on other sites More sharing options...
