Member BlackPredator Posted May 7, 2015 Member Report Share Posted May 7, 2015 Hello everybody I have the following problem: Does 3D Coat actually export ambient occlusion maps? Because from what I´ve seen so far, the "baked occlusion" layer doesnt appear in the export files. Is there a special way to do this or is it already doing it (like merging it into color-map) or is 3D coat not able to export AO-maps at all?? Thanks for every answer Cheers BP Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 7, 2015 Report Share Posted May 7, 2015 Try this hope it help Quote Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted May 7, 2015 Contributor Report Share Posted May 7, 2015 By default, 3D-Coat bakes AO into colour map, unless you hide layers that contain the occlusion or you don't have occlusion layers at all. I think the only way to export pure ambient occlusion is to set all AO layers to Standard blend mode and export them as colour. Quote Link to comment Share on other sites More sharing options...
Solution Javis Posted May 7, 2015 Solution Report Share Posted May 7, 2015 You can export an AO map from the export prompt, it is in the list of map you can export. Andrew out it in a few builds ago. Quote Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted May 7, 2015 Contributor Report Share Posted May 7, 2015 Indeed you can. I didn't notice it. Quote Link to comment Share on other sites More sharing options...
