[Solved] No baking from retopo to paint
Go to solution Solved by Hammers,
Just thought I'd start my own thread for clarity.
I've done a sculpt, which has been retopoed and unwrapped, but when I try to bake it to ppp, I get a 'blank' normal map and the retopo geometry doesn't go across.
As a stopgap I tried exporting my hi poly sculpt to Blender, but the export also fails. I get a lot of vertices all at the same point in space.
Here is my file. I'm just trying to paint the horns.
Thanks in advance.
https://www.dropbox....sRetopo.3b?dl=0
A question, - when you set your scene scale to 1 to avoid this sort of issue will it still export at the original size if you clicked the 'yes' to the dialogue to remember its size when you imported it the first time?
T
