Member kritskiy Posted June 13, 2015 Member Report Share Posted June 13, 2015 Hi everyone, I don't get why 3d Coat doesn't save the texture in my project. Here's what I'm doing: 1) import fbx to paint on 2) Texture > Import > Layers Color to import base color and AO layers I have 3) painting, saving .3b file, closing 3d Coat 4) open file again, my AO layer is there, but layer 0 is flat grey color What's going on? I'm pretty sure it wasn't like that on 4.5 Beta (I just updated to 4.5.03, osx) Quote Link to comment Share on other sites More sharing options...
Solution Carlosan Posted June 13, 2015 Solution Report Share Posted June 13, 2015 Layer0 is used for internal calculation must not be used for paint will you please try the same process adding a new layer first ? Quote Link to comment Share on other sites More sharing options...
Member kritskiy Posted June 13, 2015 Author Member Report Share Posted June 13, 2015 Wow, thanks Carlosan, using the different layer works! But how should I know that Layer 0 can't be used to draw on? Maybe it should be locked or named something like 'DONT PAINT HERE'? Layer0 is used for internal calculation must not be used for paint will you please try the same process adding a new layer first ? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 13, 2015 Reputable Contributor Report Share Posted June 13, 2015 Wow, thanks Carlosan, using the different layer works! But how should I know that Layer 0 can't be used to draw on? Maybe it should be locked or named something like 'DONT PAINT HERE'? We've been asking Andrew to lock this layer 0 for ages, for this very reason. Don't know why he hasn't/won't. Quote Link to comment Share on other sites More sharing options...
Member kritskiy Posted June 13, 2015 Author Member Report Share Posted June 13, 2015 We've been asking Andrew to lock this layer 0 for ages, for this very reason. Don't know why he hasn't/won't. I guess small things like that are always put off in the very end of development! Thanks for clearing this up Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 13, 2015 Report Share Posted June 13, 2015 0000918: Layer0 - by default to make it locked and rename it to Mesh Layer any +1 is welcome ! //edit solved in version 4.7.13 Quote Link to comment Share on other sites More sharing options...
Advanced Member The Candy-floss Kid Posted June 13, 2015 Advanced Member Report Share Posted June 13, 2015 A well spotted issue in need of immediate rectification. Quote Link to comment Share on other sites More sharing options...
New Member AlanSomething Posted March 14, 2019 New Member Report Share Posted March 14, 2019 Gosh, almost four years later and still no fix! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 14, 2019 Report Share Posted March 14, 2019 Hi Alan Which fix are you referring for ? Quote Link to comment Share on other sites More sharing options...
