Member neom315 Posted June 13, 2015 Member Share Posted June 13, 2015 Hello everyone. I have just start playing around with 3d coa and i most admit i love it, but i have need help on my pipeline, i am sure i am doing something totally wrong. I am working on my models in mubdox leave them at maximum res and then send them to 3d coat for texturing, import is amazingly long to import the models, then once inside there if i try to make a new material with a simple color texture to start painting (only in the color slot) painting is incredible slow, i would say un usable, so i guess i am importing the model in the incorrect way, there is anyone who can help me understand whats the correct way to do it? i import at maximum levels cause i need the displaced models coming from my sculpting of course. Thank you P.s. i am on an esacore with 24 gb of ram and a gforce 980, running 3d coat dx64 Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted June 13, 2015 Contributor Share Posted June 13, 2015 Do you convert to voxels at import? Quote Link to comment Share on other sites More sharing options...
Advanced Member Aleksey Posted June 13, 2015 Advanced Member Share Posted June 13, 2015 are you importing to paint room? maybe set it to auto-uv's? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 14, 2015 Reputable Contributor Share Posted June 14, 2015 Hello everyone. I have just start playing around with 3d coa and i most admit i love it, but i have need help on my pipeline, i am sure i am doing something totally wrong. I am working on my models in mubdox leave them at maximum res and then send them to 3d coat for texturing, import is amazingly long to import the models, then once inside there if i try to make a new material with a simple color texture to start painting (only in the color slot) painting is incredible slow, i would say un usable, so i guess i am importing the model in the incorrect way, there is anyone who can help me understand whats the correct way to do it? i import at maximum levels cause i need the displaced models coming from my sculpting of course. Thank you P.s. i am on an esacore with 24 gb of ram and a gforce 980, running 3d coat dx64 The Paint Room is primarily for working on low-polygon meshes....typically imported from other apps for texture painting. It's not designed to import uber-hi res models. However, if you import (or create one from scratch) a model into the Sculpt Room...it is designed to work with Hi Res meshes...and you have the option to use the Paint Room's painting tools to paint on that dense mesh, using what's referred to as "Vertex Painting." 3D Coat stores color and glossiness info in the vertices, rather than on a UV mapped model. What you want to do is export your low poly version from Mudbox and bake normal or displacement from that his res version, in Mudbox. Once you have your low poly mesh in the Paint Room of 3D Coat, go to the TEXTURES Menu > IMPORT > NORMAL MAP or DISPLACMENT map. If you are working with Displacement, then when you go to 3D Coat's FILE menu to import, you probably want to choose MIcroVertex rather than PPP (Per Pixel Painting). It's geared for working with Displacement maps, more so than PPP. If your model already has UV's applied in Mudbox, then they will come over during import. Just make sure KEEP UV's is selected in the IMPORT dialog...not Auto-UV. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 14, 2015 Reputable Contributor Share Posted June 14, 2015 If you want to import into the Sculpt room, then you can watch this video how to handle that Quote Link to comment Share on other sites More sharing options...
Member neom315 Posted June 14, 2015 Author Member Share Posted June 14, 2015 Thank you guys for the tips, i was importing a high poly model directly into the paint area, so i will try all your suggestion, first of all by trying to convert into voxel to see if things goes smoother. Quote Link to comment Share on other sites More sharing options...
Advanced Member Aleksey Posted June 14, 2015 Advanced Member Share Posted June 14, 2015 why dont you import into sculpt mode in surface mode? dont need to voxelize. Then go start painting on it. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member L'Ancien Regime Posted June 18, 2015 Advanced Member Share Posted June 18, 2015 why dont you import into sculpt mode in surface mode? dont need to voxelize. Then go start painting on it. What he said Quote Link to comment Share on other sites More sharing options...
