Member 3DNut Posted June 20, 2015 Member Report Share Posted June 20, 2015 I thought I would try creating my first Smart Material (kevlar carbon fiber) and I applied the images, which seem to look fine in the preview thumbnail, but when I apply the smart material to an object, the pattern is scaled up so large that you cannot even tell what it is supposed to be. How can I scale the smart material pattern up and down and save that in the material settings? Thanks, Bryson Quote Link to comment Share on other sites More sharing options...
Contributor Solution Michaelgdrs Posted June 21, 2015 Contributor Solution Report Share Posted June 21, 2015 Press reset and Use the magnifier on the upper bar. Quote Link to comment Share on other sites More sharing options...
Member 3DNut Posted June 22, 2015 Author Member Report Share Posted June 22, 2015 Hmm...okay, thanks. So I guess that means that there isn't anyway to change the scale and save it to the material, but rather just handle the scale issue every time it is applied to an object, is that correct? Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted June 22, 2015 Contributor Report Share Posted June 22, 2015 I believe it takes the scale of the texture.... Quote Link to comment Share on other sites More sharing options...
