Auto-Retopology wizard gone with ESC. How do I bring it back?
3DNut
Go to solution Solved by Michaelgdrs,
During auto-retopology, the phase where I designate edge flows with guide strokes to be exact, I pressed ESC and the wizard disappeared but I am not finished with the auto-retopology process. How do I bring the wizard back so that I can finish.
  • Solution
Just restart the process and it will keep everything you have done so far.
There might be a short-cut to bring it back that i don't know of , so you can wait a bit for someone else to answer as well.
It works on cancel , NOT IN ESCAPE
Yeah I've run across this one a lot while learning the Autotopo tools; typically I'm looking for a way to remove the drawn strokes to draw them over again.
What I do now (when I remember) is to delete the strokes before I start the autotopo process.
-Will
Well thanks for letting me know that I can auto-retopo again and access my same settings, density masks and edge flow strokes. I wanted to refine my results and armed with that knowledge, I was able to save right before the last step and then leverage that ability.
