Member 3DNut Posted June 30, 2015 Member Share Posted June 30, 2015 I used Calculate Occlusion in the Textures menu of the Paint Room and now I would like to export my AO map so that I can use it in Unity. The problem that I am having is that I can't figure out how to export an AO map and I don't see it in the Textures>Export menu. Thanks in advance for the help, Bryson Quote Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted June 30, 2015 Contributor Share Posted June 30, 2015 You will find the option under File->Export model with textures. Quote Link to comment Share on other sites More sharing options...
Member 3DNut Posted June 30, 2015 Author Member Share Posted June 30, 2015 (edited) You know, I tried that but it did nothing but produce an obj and mtl file. I tried it again following your response. I am not sure what the problem was but I appreciate the help. Thanks. Edit: Yeah, sorry that wasn't very clear. When I tried it the second time it worked. Edited June 30, 2015 by 3DNut Quote Link to comment Share on other sites More sharing options...
Contributor Solution ajz3d Posted June 30, 2015 Contributor Solution Share Posted June 30, 2015 (edited) Did you select ExportAO? Okay, never mind. I'm glad you got it resolved. Edited June 30, 2015 by ajz3d Quote Link to comment Share on other sites More sharing options...
