Member 3DNut Posted July 5, 2015 Member Share Posted July 5, 2015 I went through and tested all Voxel and Surface Tools to see which ones would properly use the Brush Alphas with the Stamp Mode Stroke. One of the features that I am not sure I like is that 3D-Coat saves everything that I do, so if I tweak something while experimenting, that is how it is the next time that I open 3D-Coat. That would be great if I knew what I was doing, but since I am just learning, I like the option of being able to return to defaults. I see where I can restore the workspace and hotkeys, but I don't see where I can reset the Tools so that they have their default Alphas, Strokes and settings. If you know if resetting the sculpt tools to their defaults is possible, please let me know. Thanks. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution AbnRanger Posted July 5, 2015 Reputable Contributor Solution Share Posted July 5, 2015 There is a checkbox in the Preferences panel > under the General tab > Remember Brush alpha for each tool (something like that...can look it up now, but it's toward top). Sometimes you want 3D Coat to remember and sometimes you don't. That's what it is there for Quote Link to comment Share on other sites More sharing options...
New Member bbvb17 Posted July 27, 2015 New Member Share Posted July 27, 2015 Thank you. I was about to lose my mind. Somehow I switched to stamp mode. I had no idea how I did, and I had no idea how to get out of it. Unchecked the remember brush alpha and restarted. Quote Link to comment Share on other sites More sharing options...
