Big test with 3D-Coats Autopo routine update
Taros
Hi friends.
I have prepared a big Autopo test with over 20 tests to find the right settings for the most situations.
Check the final results and read the basic rules how to use the Autopo routine on my blog:
http://bit.ly/1ghKaNO
Best wishes
Chris
Attached you see the template. I 've tested the best settings with my first autopo test model and it worked fine.
  • Like 6
Appreciate the time spent on this, I'll definitely give these settings a test and report my findings when I do!
Thank you. Below the result images you will find my ratings for the results. 5 stars are the best settings.
Taros, this is great. Many thanks for taking the time to do and share this.
You are welcome. Of course you can still tweak my values, but overall you should get good results.
Thanks Taros, added to my notes. Very helpful.
