Member red2blue Posted July 22, 2015 Member Report Share Posted July 22, 2015 Hi,I have a small problem. After using a stencil (now it is turned off) I get this kind of frame around my brush. If i hit alt and turn the object it goes away, but it is annoying. Restart of 3d-Coat doesn't helped.Does anybody got an idea what it is? I don't have this with a new projetct. Really appriciate some help. Thanks! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 22, 2015 Report Share Posted July 22, 2015 Hi The video card drivers are up to date ? Quote Link to comment Share on other sites More sharing options...
Member red2blue Posted July 22, 2015 Author Member Report Share Posted July 22, 2015 (edited) Hi carlos,thanks for the quick answere. I use the newest Nvidia 353.30 Drivers. I got a Geforce 960 GTX. I also get strange colors If I do a selection for the voxel extrude. I attach a screen. The colors of the selection move by moving the mouse. I use 3d-Coat 4.5.0.7 Edited July 22, 2015 by red2blue Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 22, 2015 Report Share Posted July 22, 2015 Your OS is windows ? Try using DX version Are you using the last version ? Quote Link to comment Share on other sites More sharing options...
Member red2blue Posted July 22, 2015 Author Member Report Share Posted July 22, 2015 I use Windows 7 64 Bit Ultimate. I tried all versions DX/GL with/without CUDA. 3D-Coat is version 4.5.0.7.Thanks Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 22, 2015 Report Share Posted July 22, 2015 Using another model... do you have the same result ? Quote Link to comment Share on other sites More sharing options...
Member red2blue Posted July 22, 2015 Author Member Report Share Posted July 22, 2015 Using another model... do you have the same result ? No, it is just this one. It started after using some stencils. Seems, that the stancils got a frame, and the frame is still valid even if the stencil is turned off. I copied every content now into new layers and deactivated the old ones (copy and merge with) and now it is gone. Strange. Another question: If I use voxel extrude, is it normal, that 3d coat is turning the active layer into a surface layer? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 22, 2015 Report Share Posted July 22, 2015 Yes, voxel extrude tool work in surface mode These tools function in a polygonal form, and then when finished sculpting, transfer by way of baking details to the voxel sculpture. This allows for a much faster and much improved way of sculpting. This video covers the Sf.Extrude tool & the Extrude* Direction settings.* Early tool name descriptions was renamed in current versions 1 Quote Link to comment Share on other sites More sharing options...
Member red2blue Posted July 23, 2015 Author Member Report Share Posted July 23, 2015 Yes, voxel extrude tool work in surface mode These tools function in a polygonal form, and then when finished sculpting, transfer by way of baking details to the voxel sculpture. This allows for a much faster and much improved way of sculpting. This video covers the Sf.Extrude tool & the Extrude* Direction settings. * Early tool name descriptions was renamed in current versions Hey Carlosan, thanks a lot for your help and the information. Will take a deeper look at the video. Thanks! Quote Link to comment Share on other sites More sharing options...
