Projection Pattern? Color Stencils?
Boonta
Go to solution Solved by Javis,
  • Solution
Hi!
Smart Materials, using the Fill Tool, and in the Tool Options panel for the Fill Tool click "Layer". That'll fill the entire layer with whatever Smart Material you have.
If you want a custom one, you'll need to construct one first of course. :) Hope that helps.
cool yeh i seemed to be able to get the effect i was after by creating a smart material with just a color image i wanted to splatter/paint over my object. worked pretty well. removing the smart material preivew window sped up the workflow as well, it took way to long to preivew the material updates after you rotate the model.
