Member zFarm Posted August 2, 2015 Member Share Posted August 2, 2015 Hi Im just learning ..l have the demo of 4.5 but can't seem to find decimate. I played with resample but that not taking any curvature info. just straight up or down rez. Thanks! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 2, 2015 Share Posted August 2, 2015 Hi ! This video covers the poly reduction method (decimation) in the Multi Res toolset/workflow in 3D Coat. 1 Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted August 2, 2015 Contributor Share Posted August 2, 2015 Hi Im just learning ..l have the demo of 4.5 but can't seem to find decimate. I played with resample but that not taking any curvature info. just straight up or down rez. Thanks! In sculpt mode, hit the 'W' key to see your mesh. Then in the Geometry menu, select "Decimation" and follow the prompts. No need to downgrade the volume layer. Quote Link to comment Share on other sites More sharing options...
Member zFarm Posted August 2, 2015 Author Member Share Posted August 2, 2015 Perfect.. thanks Tony. Yes thanks for the video maybe I was to impatient. I was looking through the docs and was frustrated.. I didn't realize you had to be in sculpt mode. Quote Link to comment Share on other sites More sharing options...
Member Vorocity Posted September 10, 2015 Member Share Posted September 10, 2015 Hello, I have the same issue using 3DC 4.5. The video above is referring to Multi-res workflow, but I just want to Decimate the actual Voxel object (if possible) or alternatively convert the voxel object to a quad mesh and decimate that. My end goal is to export a hard body type sculpt out to LightWave but I don't want or need to go to a low poly mesh (retopo), I just want to decimate the mesh somewhat on the hard surfaces prior to export, keeping lower poly counts on flat surfaces, but higher poly where required on the curves, which I understand decimate is used for. It seems the decimate feature is there in the sculpt room under Geometry, but it's grayed out. I also read references to decimate brushes, however they are also not available the the sculpt room under 4.5. Thanks. Quote Link to comment Share on other sites More sharing options...
Member Vorocity Posted September 10, 2015 Member Share Posted September 10, 2015 Ok I see now that it must be in Surface Mode to work with decimate. Makes sense. I guess I need to re-frame the question. Noob questions, but what is the proper path to go from editing a voxel object, to working it in Surface Mode in the Sculpt panel? The only way I was able to go from voxel to Surface Mode was to export as an obj then load it for "Surface Sculpting" which seems like a strange process. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted September 10, 2015 Contributor Share Posted September 10, 2015 When in Voxel mode, click on the 'V' in the volume window and hey-presto, your in Surface mode. Quote Link to comment Share on other sites More sharing options...
Member Vorocity Posted September 11, 2015 Member Share Posted September 11, 2015 Ha ha, ya, had to be obvious. Thanks Tony. Quote Link to comment Share on other sites More sharing options...
