New Member Aethaleon Posted August 5, 2015 New Member Report Share Posted August 5, 2015 For some reason, whenever I paint with a metal smart material, it paints black. What is going on? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 5, 2015 Report Share Posted August 5, 2015 Hi Could you test version 4.5.09 ? ty Quote Link to comment Share on other sites More sharing options...
Javis Posted August 5, 2015 Report Share Posted August 5, 2015 It's working OK for me here. I see you're on Windoze, which version are you on? Also like Carlosan said, try the latest build. The build you're on is quite old at this point, and still very much a beta (more so than the current builds), and is prone to bugs. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 6, 2015 Report Share Posted August 6, 2015 Using version 4.5.09 i got the same black result at paint Deleting Ambient Occlusion layer solve this issue Quote Link to comment Share on other sites More sharing options...
Advanced Member Denis Posted August 6, 2015 Advanced Member Report Share Posted August 6, 2015 Seams to work for me. Didn't have to delete the AO layer. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 6, 2015 Report Share Posted August 6, 2015 Hi Denis I cant get color if AO is generated automatically Quote Link to comment Share on other sites More sharing options...
Solution carrots Posted August 6, 2015 Solution Report Share Posted August 6, 2015 Please try this hotfix: https://drive.google.com/open?id=0B2DibXAfdFRaYXRQOW01ZjRob3M Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 6, 2015 Report Share Posted August 6, 2015 Quote Link to comment Share on other sites More sharing options...
Advanced Member Grimm Posted August 6, 2015 Advanced Member Report Share Posted August 6, 2015 I have the same issue on the 4.5.08 Linux version, I was thinking that maybe it was because of an older version of the smart materials that is causing it? Bump and gloss would work but the color would come out grey and very dark. I haven't looked into to it very much though. Jason Quote Link to comment Share on other sites More sharing options...
carrots Posted August 6, 2015 Report Share Posted August 6, 2015 I have the same issue on the 4.5.08 Linux version, I was thinking that maybe it was because of an older version of the smart materials that is causing it? Bump and gloss would work but the color would come out grey and very dark. I haven't looked into to it very much though. Jason Try select occlusion layer, and after layer you want to draw. Quote Link to comment Share on other sites More sharing options...
Advanced Member Grimm Posted August 7, 2015 Advanced Member Report Share Posted August 7, 2015 Thanks carrots, I did some more testing, but your suggestion didn't help. It doesn't happen with all of the materials, just some of them. I'm not sure what the combination is that causes the error. Here is an example: This is after I painted a large part of the chair seat. Thanks, Jason Quote Link to comment Share on other sites More sharing options...
carrots Posted August 7, 2015 Report Share Posted August 7, 2015 Thanks carrots, I did some more testing, but your suggestion didn't help. It doesn't happen with all of the materials, just some of them. I'm not sure what the combination is that causes the error. Here is an example: no_paint.png This is after I painted a large part of the chair seat. Thanks, Jason This should be corrected in the next update for linux. If the problem remains - please let us know. Quote Link to comment Share on other sites More sharing options...
Advanced Member Grimm Posted August 8, 2015 Advanced Member Report Share Posted August 8, 2015 Excellent! Thanks! I'm assuming that this would be version 4.5.10? I just tried 4.5.9 and it was still broken. Jason Quote Link to comment Share on other sites More sharing options...
