Aethaleon 0 Report post Posted August 5, 2015 For some reason, whenever I paint with a metal smart material, it paints black. What is going on? Share this post Link to post Share on other sites
Carlosan 2,464 Report post Posted August 5, 2015 Hi Could you test version 4.5.09 ? ty Share this post Link to post Share on other sites
Javis 523 Report post Posted August 5, 2015 It's working OK for me here. I see you're on Windoze, which version are you on? Also like Carlosan said, try the latest build. The build you're on is quite old at this point, and still very much a beta (more so than the current builds), and is prone to bugs. Share this post Link to post Share on other sites
Carlosan 2,464 Report post Posted August 6, 2015 Using version 4.5.09 i got the same black result at paint Deleting Ambient Occlusion layer solve this issue Share this post Link to post Share on other sites
Denis 21 Report post Posted August 6, 2015 Seams to work for me. Didn't have to delete the AO layer. Share this post Link to post Share on other sites
Carlosan 2,464 Report post Posted August 6, 2015 Hi Denis I cant get color if AO is generated automatically Share this post Link to post Share on other sites
carrots 54 Report post Posted August 6, 2015 Please try this hotfix: https://drive.google.com/open?id=0B2DibXAfdFRaYXRQOW01ZjRob3M Share this post Link to post Share on other sites
Grimm 47 Report post Posted August 6, 2015 I have the same issue on the 4.5.08 Linux version, I was thinking that maybe it was because of an older version of the smart materials that is causing it? Bump and gloss would work but the color would come out grey and very dark. I haven't looked into to it very much though. Jason Share this post Link to post Share on other sites
carrots 54 Report post Posted August 6, 2015 I have the same issue on the 4.5.08 Linux version, I was thinking that maybe it was because of an older version of the smart materials that is causing it? Bump and gloss would work but the color would come out grey and very dark. I haven't looked into to it very much though. Jason Try select occlusion layer, and after layer you want to draw. Share this post Link to post Share on other sites
Grimm 47 Report post Posted August 7, 2015 Thanks carrots, I did some more testing, but your suggestion didn't help. It doesn't happen with all of the materials, just some of them. I'm not sure what the combination is that causes the error. Here is an example: This is after I painted a large part of the chair seat. Thanks, Jason Share this post Link to post Share on other sites
carrots 54 Report post Posted August 7, 2015 Thanks carrots, I did some more testing, but your suggestion didn't help. It doesn't happen with all of the materials, just some of them. I'm not sure what the combination is that causes the error. Here is an example: no_paint.png This is after I painted a large part of the chair seat. Thanks, Jason This should be corrected in the next update for linux. If the problem remains - please let us know. Share this post Link to post Share on other sites
Grimm 47 Report post Posted August 8, 2015 Excellent! Thanks! I'm assuming that this would be version 4.5.10? I just tried 4.5.9 and it was still broken. Jason Share this post Link to post Share on other sites
