Advanced Member Mighty Pea Posted September 24, 2015 Advanced Member Report Share Posted September 24, 2015 Hey guys, I need to paint transparency, which I've traditionally always done by erasing layer 0. Now, whenever I reopen the file layer 0 is fully gray again and consequently lost all transparency. Is there a new way to do this, or is this a bug? Quote Link to comment Share on other sites More sharing options...
Solution Javis Posted September 24, 2015 Solution Report Share Posted September 24, 2015 If you hide layer 0 before export, you'll get transparency, assuming you've left some "holes" in the other paint layers. Sounds like you have. Sent from my SM-G900P using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Mighty Pea Posted September 26, 2015 Author Advanced Member Report Share Posted September 26, 2015 That works! Was there a change in how Layer 0 works? Because I used to do it by selectively erasing parts of that, but it seems like Layer 0 is protected? Quote Link to comment Share on other sites More sharing options...
Javis Posted September 26, 2015 Report Share Posted September 26, 2015 I'm not entirely sure on that to be honest, I've always had hit or miss erasing/painting on layer 0 so I've stayed away from doing it that way. A few years ago Andrew told me to hide layer 0 instead, and ever since I've had no issues. Glad it helped! Sent from my SM-G900P using Tapatalk Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 26, 2015 Report Share Posted September 26, 2015 Solved in new version whenever I reopen the file layer 0 is fully gray again and consequently lost all transparency. Quote Link to comment Share on other sites More sharing options...
