Member mansfield Posted September 29, 2015 Member Report Share Posted September 29, 2015 Hi all, Using autopo for perpixel, I go through all the stages fine, until bake occlusion. When I hit okay, the occlusion menu just vanishes and nothing happens, no calculations are performed at all. I get my autoped model in the retopo room, but nothing in paint room (exept high density voxel mesh) and no occlusion layer. What am I missing? Regards 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 29, 2015 Report Share Posted September 29, 2015 Hi ! Which version/OS are you using ? Quote Link to comment Share on other sites More sharing options...
Member mansfield Posted September 29, 2015 Author Member Report Share Posted September 29, 2015 Apologies carlosan should have added that earlier. Its 4.5.16 and running on win 8.1. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 29, 2015 Report Share Posted September 29, 2015 What if your skip the AO stage at retopo room ? * later can perform AO baking at Paint Room. Quote Link to comment Share on other sites More sharing options...
Contributor Solution Michaelgdrs Posted September 30, 2015 Contributor Solution Report Share Posted September 30, 2015 Autopo room bake menu bake w normal map (per pixel). Have you tried this? 1 Quote Link to comment Share on other sites More sharing options...
Member mansfield Posted September 30, 2015 Author Member Report Share Posted September 30, 2015 Autopo room bake menu bake w normal map (per pixel). Have you tried this? That works! Cheers. Not sure why the usual method of baking directly from the autopo menu does not - are they different methods? 1 Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted October 1, 2015 Contributor Report Share Posted October 1, 2015 (edited) Second method bakes normal as well from the sculpt to your retopo mesh. Now if you go and bake AO it will bake it without issues. Most important is that it created the UVS so AO can be baked on. Edited October 1, 2015 by Michaelgdrs Quote Link to comment Share on other sites More sharing options...
