Keeks
LightWave Applink
Do you think 3dCoat will get updated to work with 2018 lwo file formats?? Currently having to export them as 2015 objects, but ideally it would be cool if 2018 could be supported, along with its new PBR shader.
As far as I can tell, Python now fully supports writing materials etc. As that's how Oliver Hotz does his plugins.
Thanks guys!
Tim
Thanks guys!
Tim
I hope so to Tim.
15 hours ago, splinetime said:
No.... It feels orphaned.
Lightwave itself, seemed/seems orphaned, so there is that. :D Nothing wrong with asking, but if they broke the file format, it might be a while til a 3rd party developer steps up.
Thanks guys!
Tim
Anything broken when exporting them as OBJ's like all the other applinks do?
23 hours ago, Styler said:
I'm currently working on an update for LW applink. I believe that this will be done soon-ish.
Great news... Thank you.
Do you know if this will mean the new lwo format will be supported too?
I'm updating LW part. Since Coat cannot handle LWO 2018 I'll be using different file formats for sending data between apps.
Thanks a lot !
Good to see a new AppLink for 3DCoat and Lightwave 2018 !!!
This will be really helpful !
Hopefully LWO 2018 format will be supported natively in 3Dcoat since PBR arrived in Lightwave and it makes so much sense now.
Thank you for finding a way of roundtripping between the Apps by now.
Excellent !!!
Regards,
Marcus
Really looking forward to this !
Exporting a 2015 LW model to get it into 3dC, ... then bringing it back in to LW, ... and setting up and monkeying with the surface nodes gets pretty time consuming.
Sorry guys. I'll will not able to finish a new applink due to complexity and time that I need to spend with it. Too much work for me, besides my primary job. If someone is interested to continue I can provide the source code and instructions how to accomplished it.
Sad to hear but understandable.  Perhaps you could post a quick note on the Newtek Lightwave forum and let them know there as well.  Maybe that'll flush someone out that can continue.
Here is a brief explanation.
All previous applinks used material slots and that was quite easy to do because we have access to this part through scripting language or lwsdk. Somebody can say "Dude.. But we have node editor and many cool nodes! Why don't you make shaders using this approach?!". I have to say this is a first thing I'd do,  especially in LW 2018 where legacy materials give you a bounded potential. Sounds good in theory, but the access to nodes is heavily limited in lwsdk. Even in LW 2018! You can write and compile your own nodes as additional plugins, and later use them in NodeEditor, but there is no way to create a simple node from script or code, only manually. From the developer perspective a node is just a black box, which does some magic stuff. I spent a lot of time trying to get access through different hacks, but apparently it's not possible. The only one way that I could see is writing your own LWO parser and override information directly in lw object files. This is a pretty big task and require a lot of patience and time. Beside that not every LWO chunk has a description in the sdk documentation. If you still interested please try =), it's pure fun!
Edited by Styler
Can you put the code up in GitHub or some equivalent location?  Otherwise, what license would apply, and how do we obtain the source code?
I can't make any promises, but there's a fairly decent chance someone will finish the AppLink for LW2018.
If someone wants to give it a go...
On 7/9/2018 at 4:34 PM, Styler said:
Here is the archive with the source files
lw_applink_source_latest.zip
Styler,
I undestand completely about not having time to continue development.  Hopefully the new LW2019 SDK will open some of this up but I'm curious what I can do with it, or at least learn from it.
I sent you a direct message with a couple of questions abou the code.   Look forward to hearing back.
Scott
there is one for LW2019 (release > soon)
https://forums.newtek.com/showthread.php?157535-3DCoat-Applink-LW2018-source-code/page2
note, it is commercial and will cost $175 (since it is bundled with LightWave ODToolSet)
I have LW, 3DC, and now OD Tools. With using OD tools, I can now import and export between LW and 3DC no problem. My only question is on the Export Preset options in 3DC. As there is no preset specific to LW, which one would be the best bet or recommended option. By default, it is at 3DMax(ArchDesign) and this works, but I'm not sure it is the optimal setting. Any thoughts on which one would be the best for importing into LW Layout? I definitely notice differences between them.
I haven't tried them all but I've been using the default and it seems to work fine. I also found for the UV map using Keep Sharp Corners  (Smooth But Keep Corners in 3DC I think) tends to help.
Hi
Any info about LW2019 applink development ?
Thx in advance
