Michaelgdrs
Thanks a lot David. You should see this in the DK2 3D Coat has boosted my work soooo muchhhhhhh.
I have it on unwrap mode so it takes 100% advantage of the custom uvs ;)
Edited by Michaelgdrs
CAUTION TO ALL WHO ASK
BEST PROJECTION FOR ALL MY MATERIALS TO WORK PROPERLY IS
UV MAPPING , not cube mapping , not from  camera , ONLY UV MAPPING
Allo aloo Artur ,
wood is the next one.
Trying to get as much as possible from the ones i already have (around 60 woods count so far) so it really worth peoples $$.
Got too much work on my hands and testing is killing me , plus that every since and a while the materials bug hits me and i must get materials back from backup and re organize them , I have one folder that i got all 400 500 ++ materials in (proved a not so smart movement) .
Anyway , will try to get this up in the next 24 hopefully.
Yeap you are so right.
I got hired full time earlier than expected and things gone out of control , i couldnt even get the extra guys that i need.
So excited and so many projects i am working on with this studio that i sleep 2 or 3 hours maximum.
FOR THEA RENDER
Pipeline 1
Basic workflow :
Albedo translates  in colour
AO translates  in highlights with intensity tweaks regarding your light setup
Roughness translates in shininess
Metalness translates in reflection again you need to  tweak   Fresnel and refraction
Pipeline 2
Substance Thea Converter
https://www.thearender.com/site/index.php/features/substance-to-thea-material-converter.html
Unique Features
By taking advantage of the Substance Engine, changes to the Substance files can be made inside the converter. The results can be applied automatically to a Thea material which the user can preview under different settings. Physically-based materials designed with the Metallic/Roughness template are automatically converted to their equivalent in the Thea material system. Additionally, the user can create his/her own combinations although the result is not guaranteed to be physically accurate. Batch conversion of Metallic/Roughness Substance files to Thea materials or to a Thea material pack is also supported.
FOR THEA RENDER
Pipeline 1
Basic workflow :
Pipeline 2
Unique Features
Sorry I'm totally new to this with 3D Coat and PBR-Materials. I use C4D and Thearender. Does this mean that I model my house in my CAD, load it in 3DCoat, unwrap and paint it and make materials for what I want and then translate these 3D-Coat-materials to Thearender and can use all informations of it? If you're new to that it is like a big mountain to climb...
Greetings tildee ,
thats the cost of using multiple software in order to achieve a final quality result.
You will get used to it.
What i can ensure you is that 3D Coat is one of the finest sculp , paint , retopo , uv software around and it will serve you well.
I apologise for the misunderstanding ,
With any smart material (including the ones i sell too) you can get them into 3D Coat and start painting.
On export 3D Coat will let you get 3 export options / workflows
1) Gloss / Colour Specular
2) Gloss metallness
3) Roughness / metallness
With those textures you can work with Thea following the instructions i gave a couple messages back.
If you think you cant do it or its too fuss of a procedure please do not buy.
For thea users :
Easiest way of doing this is to get any substance material and run the converter.
It will auto create the textures and assign them to a material.
All you have to do is see what it created and just replace with your textures  ;)
Thanks for the tips on Thea Render, Michael. As I am understanding it, the output method should be Glossiness/Metalness for unbiased (physically based render engines), and the Glossy/Spec Color for biased engines. Feel free to correct me, if I'm wrong, but based on what I've seen/read thus far, that seems to be the right approach. Here is a nice video tutorial covering the Thea > Substance Converter:
More images here
https://www.artstation.com/artwork/0z3KE
Wip from AAA upcoming VR game
All material are custom and you can find them here for sale
https://gumroad.com/michaelgdrs
Packages used
3D Coat PBR Procedural WEATHERING SMART MATERIALS
3D Coat PBR Procedural METAL SMART MATERIALS
https://gumroad.com/products/ivnQl
https://gumroad.com/products/NvCvVr
Until Wood collection finally gets fully tested i am uploading the clay collection for those who were asking for it.
$1.99 for the first 24 hours for the community ;)
  • Like 4
Yes correct , they  work fine with all mapping methods / projections.
I just created them in unwrap mode so in my eyes they work best there.
Of course there are cases that cube mapping beats them all.
Greetings to all
Just released parts 1 and 2 of wood collection.
Parts 3 4 and 5 will be released as well in the next days.
A special package containing all 5 will be released as well in a lower price.
  • Like 3
