3D Coat Forums
Koljasha
FBX Import not working
Hello!
Sorry for my English, I use a translator.
I have after updating Windows 10 to Windows 10 1511 (the last major update), stopped working import FBX files.
If I make a Model for Microvertex Painting, writes that The Model is Empty.
If I make a Model for Per Pixel Painting, nothing happens at all.
In other programs FBX opens without problems.
I tried various models.
Even if import OBJ image in 3D-Coat. Then save it as an FBX, then the FBX does not open.
Such a problem on my 4.5.19 and the latest beta ...
Can anyone suggest how to solve - FBX I was very comfortable ...
You can still work with obj as a workaround to get your job done.
This issue i think its the first time that has been brought up , when Dev team or a moderator see this thread they will answer back.
Until then hold on and work with obj until a solution is found (it will be found)
Hi
We found a bug because language letters are unrecognized, try switching your OS to english language as workaround or put the model on another folder as C:\Temp
Another option will be change to FBX version 2012, it works.
Dismayed that this bug is still present - switching to English language didn't help. Don;t want to have to break flow to go to OBJ, it messes up scales
Try exporting as fbx 2014
Hope it help.
Carlos is correct.I had the same problem a couple of years ago till I exported from Maya LT Using Fbx 2014.
