Baking transparency?
Hasuman
Go to solution Solved by Michaelgdrs,
Hi,
I'm sculpting a character with raggedy clothes for my game. I'm wondering if it's possible to bake the raggedy parts so that it generates an alpha map for them? For example, I would model a simple cylindrical mesh for a skirt with holes/hanging parts in it and it would project those holes as an alpha as a seperate texture or as an alpha channel.
  • Solution
It can be done .
Layer 0 set opacity to 0 and hide the layer.
Now make a new layer and erase with the erase brush some parts.
Bam you have transparency.
If you have additional layers you need to erase those as well included AO.
  • 1 month later...
It can be done .
I've gotten the basics of this working but wondering if there's a way of ganging layers so that the erasing operation is in sync so to speak?  I'm working on a fish & trying to figure out the best approach for transparency & translucency.
Similarly, I'm not fully understanding the RMB function of Make Transparent for a layer.  Seems that the Blend mode is important for ths to work properly.  Any tutorials anywhere on this?
Thanks.
