Educational to Professional - where do I put my key?
sazberryftw
Go to solution Solved by AbnRanger,
  • Solution
If I uninstall and reinstall do I lose my settings and preferences?
What I would try to do, in your case, is to move your LICENSE.DAT file outside of the MyDocs/3D Coat V4.5 directory > install the latest build > when you open 3D Coat, you should get the prompt to add your registration key. Enter your new one and see if that works.
....If not, you could temporarily re-name your current MyDocs/3D Coat 4.5 directory > install latest build > move the subfolder content from the previous, re-name directory, to the new one.  Don't move the individual files, like Options.xml and such.
Thank you. I did your first suggestion and it worked. :) Is there somewhere I can post about getting this system improved? I feel like this information should be given to me when I upgrade my license, or the system should be easier - e.g, having an option called "Upgrade my license" within the software.
Thanks again!
Here what Don says very correctly is what the links i send you describe as well.
Oh just read that it worked so all good.
ENJOYYYYYYY
